RV7 wing attachment question
Old July 30th 07, 01:35 AM posted to rec.aviation.homebuilt
TerryJ
Default RV7 wing attachment question
A close relative is building an RV7 and is ready to attach the wings for the
first time. The alignment of the holes in the center spar section front and
back is off enough that a hardware store bolt will not pass through both
sides. I estimate the alignment is off by 1/32 to 3/64 inch perhaps more on
the port side. I am not an aeronautical engineer nor have I built a plane
but to me this is excessive and would tend to stress the close tolerance
bolts and spars as the bolts are forcibly driven in.
He says his 'mentor', who has built two planes, says all is OK (though the
'mentor' has not personally inspected the plane).
Am I being paranoid? My concern is for his life....
Kind regards,
Terry
Old July 30th 07, 02:44 AM posted to rec.aviation.homebuilt
Matt Whiting
the first time. The alignment of the holes in the center spar section
front and back is off enough that a hardware store bolt will not pass
through both sides. I estimate the alignment is off by 1/32 to 3/64 inch
perhaps more on the port side. I am not an aeronautical engineer nor
have I built a plane but to me this is excessive and would tend to
stress the close tolerance bolts and spars as the bolts are forcibly
driven in.
the 'mentor' has not personally inspected the plane).
The only place to get a definitive answer is Vans Aircraft.
Matt
Old July 30th 07, 04:19 AM posted to rec.aviation.homebuilt
Jim Logajan
The distant second best place is to ask on http://www.vansairforce.net/
Old July 30th 07, 02:05 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Followed closely in thrid by the RV list at Matronics.com
Old July 30th 07, 06:22 PM posted to rec.aviation.homebuilt
yeah, you're too paranoid, those spar plates move around quite a bit.
might need the rivet gun to help drive them in.
Also, mic the hardware bolts. I ended up with a batch that where over
sized which is uncommon for cheap china bolts.
rv7a 320 hrs.
hr-2 20 hrs.
Old July 30th 07, 07:31 PM posted to rec.aviation.homebuilt
TerryJ
Van's response....
"Terry, This is not uncommon and will not be a structural problem. To help
ease installation,
install a hardware store bolt from the front and one from the back
side...these bolts need not
go thru all the way. Having the spar in between will pull the structure
into alignment and allow
adjacent bolts to be installed fully without as much stress.
When installing the close tolerance bolts, the same method can be used. In
addition, the
bolts can be left in the freezer or on dry ice and lubricant applied.
Our proto shop has used bottle jacks to 'spread' the fuselage at times to
install A-model gear
weldments etc. There is more flex in the fuselage than you'd expect.
van's
rv7a 320 hrs.
hr-2 20 hrs.
X-48B Blended Wing Body Research Aircraft Takes First Flight [1 attachment] §qu@re Wheels[_4_] Aviation Photos 5 July 30th 07 06:17 AM
Wing walk ply question. Mustardbuilder Home Built 20 January 28th 07 10:16 AM
Rotor-wing question D. Andrews Rotorcraft 8 October 2nd 05 11:43 AM
Folded wing tip question a425couple Naval Aviation 35 May 12th 05 11:40 PM
Discus Wing question John Galloway Soaring 6 August 23rd 03 07:52 AM
