Subaru EG33 JDM Questions
Old August 4th 07, 04:32 PM posted to rec.aviation.homebuilt
Default Subaru EG33 JDM Questions
I've bought a "92-96" EG33 from Engine World that was imported via
JDM. All hoses were cut and the ECU was NOT included. I've found the
number "022110" stamped on the engine housing near the flywheel.
I've been told the 92-96 EG33's were all the same engine. Can anyone
verify this or speak on that subject? I am wanting to buy an engine
manual for rebuild and everyone wants a year and model (1994 SVX). I
will also be looking for an ignition controller and ECU. Will they
all be the same for 92-96?
Any help from you guys would be greatly appreciated.
Allen Slominski
Houston, TX
Old August 6th 07, 03:15 AM posted to rec.aviation.homebuilt
Cy Galley
Be very, VERY careful using the ECU of a Subaru. At extended high power
settings it can go into "limp home mode" which is reduced power designed to
get the car to a service station BUT its NOT enough power to fly an
airplane. See "Contact!" issue 88 for details. Call 559-584-3306 to get a
copy. It could save your life.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
Allen Slominski
Houston, TX
Old August 13th 07, 06:15 PM posted to rec.aviation.homebuilt
On Aug 4, 11:32 am, "
Allen Slominski
Houston, TX
Allen,
I have the Subaru Service Manual on my web pages at:
http://www.canardzone.com/members/ph...references.htm
I hope that this helps.
Phil
Ottawa, Ontario, Canada.
Old August 14th 07, 03:53 PM posted to rec.aviation.homebuilt
Join some of the lists that discuss the suby. I've seen the info
you're asking, just can't recall where. Here're some leads
http://www.prachapter34.com/converting_engines.htm
Also check out the files in the subaru/vanagon list on yahoo groups.
A lot of guys are putting subys in the VW vanagon and working out
these sorts of ECU questions
-Kent
Subaru flywheel pto without transmission [email protected] Home Built 2 November 26th 05 08:00 AM
Subaru EA-81 Laurent Marcoux Home Built 1 May 2nd 05 02:09 PM
experimental engine-subaru Cautious Home Built 0 February 11th 04 05:34 AM
Timing on Subaru EJ22 ??? Randy Rotorcraft 1 November 9th 03 06:15 AM
What ever happened to the Subaru x-100 ? Wooduuuward Home Built 0 July 6th 03 12:53 AM
