White lead & castor oil on prop shaft?
Old August 20th 07, 04:58 PM posted to rec.aviation.homebuilt
wright1902glider
Default White lead & castor oil on prop shaft?
While attempting to distract myself from 8 hours of filing documents
on Friday, I Youtubed up the Republic / Air Corps training film on how
to field assemble the P-47 Thunderbolt. (Where I work, that's called
multi-tasking.) In the film, they describe coating the prop shaft of
the R-2800 with the "perscribed mixture" of white lead and castor oil
before installing the prop.
Just out of curiousity, how would someone comply with this procedure
now? Castol oil is easy enough to get, but white lead? Substitutes?
And what exactly does the white lead do? Does it act as a packing or
anti-corosive?
I've found that when restoring or reproducing vintage things,
attempting to find the correct materials is a real challenge, if not
impossible. When I built my Wright machine, the only easy materials to
find were the steel rod, sheet, and wire.
Harry Frey
Old August 20th 07, 07:02 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
On Aug 20, 3:58 pm, wright1902glider wrote:
... In the film, they describe coating the prop shaft of
anti-corosive?
My first thought was that the mixture might be some
sort of never seize, but then I remembered that white lead
(lead oxide I think) is a 'drier', a chemical that was added
to linseed oil or oil paints to initiate polymerization.
So now I'm thinking that this was some sort of adhesive, or
maybe an anti-corrosion coating like a very hard version
of cosmoline. I think Japaning, a predecessor to baked
enamel paint also used white lead.
Anyhow, linseed oil and oil based paints still use driers,
cobalt salt are typically used instead of lead compounds.
'Japan drier' is _something_ dissolved in solvent which
can be added to oil finishes to speed the hardening. It
is still sold today, must not contain white lead. So
my next guess would be that castor oil and Japan drier
might be an acceptable substitute. I've seen Japan drier
in catalogs and on the shelf at the BORG.
Knowing _why_ they coated the shaft, and what parts of
the shaft, would help.
FWIW, you CAN get white lead but you'd probably
have to order it from a company that sells chemicals
in general as opposed to just picking it up at a hardware
store or paint store.
FF
Old August 20th 07, 07:22 PM posted to rec.aviation.homebuilt
wright1902glider
On Aug 20, 12:02 pm, Fred the Red Shirt
Fred,
I worked for Sherwin-Williams for about 7 years but I never did figure
out what was in that can of Japan dryer. It was in some sort of
solvent.
In the film, I can't really see which part of the prop shaft they
smeared the goop on. The film did mention using light oil on a few
parts. My guess is that its either the splines, or the tapered
section. The plane in question was an early model and still had the
"razorback" canopy. They were installing an electroc prop b/c they had
to remove the brush box, and clean the brush contact ring and retainer
before installing the prop. I remember reading that the P-47s used at
least 2 different props depending on model, but its been 20 years
since I read that book.
Harry
Old August 20th 07, 08:48 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Fred,
solvent.
1,2,4-Trimethylbenzene 000095-63-6 10-15
Cobalt 2-ethylhexanoate 000136-52-7 20-25
2-Ethylhexanoic acid 000149-57-5 1-5
Manganese naphthenate 001336-93-2 5-10
Stoddard solvent 008052-41-3 50-55
Manganese 2-ethylhexanoate 015956-58-8 30-35
Zirconium 2-ethylhexanoate 022464-99-9 50-55
Cobalt naphthenate 061789-51-3 20-25
Naphtha, petroleum, hydrotreated heavy 064742-48-9 40-45
Solvent naphtha, petroleum, light aromatic 064742-95-6 35-40
Old August 20th 07, 11:03 PM posted to rec.aviation.homebuilt
Blueskies
"wright1902glider" wrote in message
anti-corosive?
Harry Frey
http://www.youtube.com/watch?v=GkrUMT1d3C4
Old August 21st 07, 12:08 AM posted to rec.aviation.homebuilt
Blueskies
"Blueskies" wrote in message ...
anti-corosive?
Harry Frey
Looks like they used the mixture as an anti-seize compound...
Old August 21st 07, 12:38 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
On Aug 20, 6:08 pm, "Blueskies" wrote:
"Blueskies" wrote in m...
n...
anti-corosive?
Harry Frey
Wow. I especially like the part where "about fifty men"
install the wing.
If white lead will harden castor oil then I would suppose the
opposite--that it was used as a thread-locking compound.
But if it does not harden, then I agree, anti-seize.
FF
Old August 21st 07, 01:01 AM posted to rec.aviation.homebuilt
Blueskies
"Fred the Red Shirt" wrote in message
install the wing.
FF
Looked like there was a separate locking gizmo to ensure the prop stayed put...
Only ten men to put the prop on ;-)
Old August 21st 07, 03:04 AM posted to rec.aviation.homebuilt
Tri-Pacer
White lead used to be a wonderful anti-sieze outlawed many years back. I
expect I'm showing my age having used it in the past. About the same era,
carbon tet was used in fire extinguishers. :-)
Paul
N1431A
KPLU
Old August 21st 07, 03:05 AM posted to rec.aviation.homebuilt
Drew Dalgleish
On Mon, 20 Aug 2007 08:58:17 -0700, wright1902glider
anti-corosive?
Harry Frey
I'm going to guess as a packing. The only other use of white lead that
I've heard of is for filling the weave on the canvas of a canoe before
painting.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Increase efficiency of rotating shaft. jigar Home Built 8 October 6th 06 05:29 AM
Subaru flywheel pto shaft [email protected] Home Built 5 November 28th 05 12:05 AM
Thrust vs Shaft Horse Power? Evan Williams Military Aviation 9 July 22nd 04 02:45 AM
Lubricating the primer shaft Michael Horowitz Home Built 9 November 20th 03 12:26 AM
