Hello Jim,
Would appreciate your comments, if any, on the following but only if it it will only take about a minute of your time. Re Collions 476X-3 Transponder Test Set What is difference between the -1 and the -3 units? Is the interrogation process initiated by an internal timer in the test set as there appears to be not any "press to test"? AND if RST is involved with magnetoes, what equipment do you use to comply with the 50 Gohm capacitor leakage test required by Slick? With thanks |
Sorry, I have absolutely no answers to either of these two questions...would
if I could. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "George McLeod" wrote in message u... Hello Jim, Would appreciate your comments, if any, on the following but only if it it will only take about a minute of your time. Re Collions 476X-3 Transponder Test Set What is difference between the -1 and the -3 units? Is the interrogation process initiated by an internal timer in the test set as there appears to be not any "press to test"? AND if RST is involved with magnetoes, what equipment do you use to comply with the 50 Gohm capacitor leakage test required by Slick? With thanks |
Get Rid of Jim Weir at Oshkosh | Bret Ludwig | Home Built | 26 | August 28th 06 03:00 PM |
Damn the Jim Weir! | Ken Finney | Home Built | 4 | July 5th 06 09:33 PM |
To Jim Weir/Others | James Lloyd | Home Built | 5 | February 25th 04 05:49 AM |
Jim Weir for Governor or RAP | R. Hubbell | Piloting | 0 | November 25th 03 04:34 AM |
Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 06:06 AM |
