Glass cockpit hard to read
Old October 6th 07, 05:21 PM posted to rec.aviation.piloting
Arno
Default Glass cockpit hard to read
Hello,
I am computer scientist and usually really like fancy technology. But
I just had my first flight with a "glass" PFD (Avidyne) and must say I
am not impressed. In particular reading altitude and airpeed from
these scrolling bands requires a lot more attention than with regular
gauges, just like reading a digital clock takes longer than reading an
analog one. Glancing at it and checking against a known picture, like
"speed at 3 o'clock is fine on final" or "altitude at 20 minutes past
midnight is minimum", just does not work anymore, instead I end up
reading the actual numbers every time I look. Does anyone feel the
same? Am I missing a particular technique?
Arno
Old October 6th 07, 06:40 PM posted to rec.aviation.piloting
Don Tuite
On Sat, 06 Oct 2007 15:21:27 -0000, Arno
Hello,
I figure it's a conspiracy to make flying as much like a video game as
possible. Pretty soon, all the pilots over 40 will be eradicated in
mid-airs and CFITs arising from display fixation, and the young'uns
will transition to simulations and never notice that they aren't
actually flying anywhere -- which will be good, because they couldn't
have afforded the fuel anyway.
These newsgroups will live on, of course.
Don
Old October 6th 07, 08:06 PM posted to rec.aviation.piloting
Mxsmanic
Don Tuite writes:
possible.
I suppose you are making a joke, but there may be considerable truth in what
you say.
As computers enter many domains in which they had not previously been used,
the "computer mindset" also tends to pollute those domains, since the ergonomy
of computer software is often a function of the preferences of the developers
who build it. I note that glass cockpits bear a suspicious resemblance to
PC-based interfaces, a likely sign that the developers knew a lot more about
PCs than they did about cockpit designs. The glass cockpits drift towards an
interface that looks like something you'd see on a laptop computer, rather
than something you'd see in a traditional cockpit. I don't think this is a
good thing. Indeed, it is one of my objections to glass cockpits, especially
the highly integrated kind often installed in small aircraft (think G1000).
Old October 6th 07, 08:26 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Don Tuite writes:
as possible.
in what you say.
used, the "computer mindset" also tends to pollute those domains,
since the ergonomy of computer software is often a function of the
preferences of the developers who build it. I note that glass
cockpits bear a suspicious resemblance to PC-based interfaces, a
likely sign that the developers knew a lot more about PCs than they
rather than something you'd see in a traditional cockpit. I don't
think this is a good thing. Indeed, it is one of my objections to
glass cockpits, especially the highly integrated kind often installed
How would you know?
You don't fly and you never will.
bertie
Old October 6th 07, 11:11 PM posted to rec.aviation.piloting
Viperdoc[_4_]
To all:
Please be aware the Anthony Atkielski (mxsmanic) is not a pilot, and has
never held an aviation medical. In fact he has never even taken a lesson,
let alone fly in a small plane.
He certainly has never flown with or operated a G-1000 or anything remotely
similar.
Old October 6th 07, 07:15 PM posted to rec.aviation.piloting
Larry Dighera
wrote in . com:
Hello,
Arno
Perhaps you should inform Avidyne of your less than satisfactory
experience with the ergonomics of their product. It would be
interesting to see their response. Who knows, you might be able to
motivate them to provide an 'analog gage' mode switch on future
versions.
http://www.avidyne.com/contact/contactus.shtm
E-Mail:
Avidyne Comm/Nav/FMS Group
420 N. Wickham Rd.
Melbourne, FL 32935
Phone: 321-751-8520
Fax: 321-751-8435
Avidyne Safety Systems Group
4800 Evanswood Drive
Columbus, OH 43229
Technical Support Phone: 800-877-0048
Technical Support Fax: 614-885-8307
Old October 6th 07, 08:01 PM posted to rec.aviation.piloting
Mxsmanic
Arno writes:
It is a matter of habit and personal preference.
Old October 6th 07, 08:25 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Arno writes:
No, it isn't, fjukkwit.
This ios almost the dumbest thng you've ever said.
bertie
Viperdoc[_4_]
To all:
similar.
Old October 6th 07, 08:41 PM posted to rec.aviation.piloting
Phil
On Oct 6, 10:21 am, Arno wrote:
Hello,
Arno
I am a fellow computer geek, and a student pilot. I usually fly a
plane with steam gauges, but a couple of times now I have flown with
digital displays. Like you, I found it a little hard to adjust to the
digital displays. The digital displays I was using presented altitude
and tachometer values simply as numbers. The analog displays I am
used to present these values as positions on a dial, showing the
current value in its context of a spectrum of values. With the analog
displays, I am used to adjusting the position of the pointer. With
the digital display, I need to simply set the correct numerical
value. It's a little mental adjustment, and given that I am a newbie
to all this it is an extra distraction.
But, I do think that it is mostly a matter of what you are used to.
If you started out working with a digital display, and had to switch
to a steam gauge, I think it would be just as much of an adjustment.
I think that the human brain is a pretty flexible instrument, and I
suspect it wouldn't take long to get used to setting a numerical value
rather than the position of a needle on a dial. Both are valid
methods of presenting the information. Either way, it is simply a
feedback mechanism you use to make sure the airplane is doing what it
should.
Phil
OSH Homerun? Glass Cockpit for the Budget-Challenged Marco Leon Piloting 4 July 28th 07 12:27 AM
winter is hard. Bruce Greef Soaring 2 July 3rd 06 07:31 AM
Why Not Use PC To Make Glass Cockpit? Le Chaud Lapin Instrument Flight Rules 52 July 19th 05 04:45 AM
It ain't that hard Gregg Ballou Soaring 8 March 23rd 05 02:18 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 02:20 AM
