Staying current overseas
Old October 18th 07, 05:16 AM posted to rec.aviation.piloting
Justin Gombos
Default Staying current overseas
Suppose a US certificated pilot is in Europe for a couple years, and
the flight review becomes due when they're there. Does it complicate
the process to get the review in the US months or even a year after
the deadline? I'm figuring my chances of finding a FAA CFI in Europe
isn't something I can count on.
PM instructions: caesar cipher the alpha chars in my addy (key = +3).
Old October 18th 07, 07:12 AM posted to rec.aviation.piloting
BT
As long as you are not flying while overseas.. no problem.. the BFR expires
and you cannot act as PIC in a US registered aircraft until you complete the
Flight Review. If you are flying overseas on your US certificate, normally
the foreign ICAO country requires you to maintain standard US requirements.
You could go 20 years... and not fly.. and only need the CFI to sign off a
flight review.. granted the smart CFI will do more than just the minimum 1hr
ground and 1hr in the air to make sure you are safe.
BT
"Justin Gombos" wrote in message
news:heARi.4853$2h2.3518@trndny01...
Old October 18th 07, 02:05 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Justin Gombos wrote in news:heARi.4853
$2h2.3518@trndny01:
There are plenty of them. Getting an airplane you can do it in is another
matter, but it's do-able.
Bertie
Old October 18th 07, 03:17 PM posted to rec.aviation.piloting
Gig 601XL Builder
You might check with AOPA. I'll bet they have a list of US CFIs who can do a
BFR overseas.
Old October 18th 07, 06:19 PM posted to rec.aviation.piloting
Robert M. Gary
If the guy is flying several hundred hours a year under his Eurppean
certificate I would not have a problem signing his BFR after the
minimum.
-Robert
Old October 18th 07, 07:01 PM posted to rec.aviation.piloting
Stefan
In most European contries you will find some N-registered planes to rent
and an FAA FI to sign your check ride or whatever. Maybe you'll have to
search a bit, depending on where in Europe you will be, but they are
available.
Old October 18th 07, 08:45 PM posted to rec.aviation.piloting
S Green
You should have little difficulty finding a FAA CFI. Just ask those who fly
N reg aircraft who does their BFR.
If the guy does not hold a JAR Instructor rating, he is not allowed to
charge for his services strictly speaking. However you are likely to find at
least one FAA instructor hanging out at any airfield that flies N regs.
Usually a couple of the pilots have gone and got his CFI to sign off his
friends and flying partners.
Old October 19th 07, 01:45 AM posted to rec.aviation.piloting
BT
He did not say he had a European certificate..
just a US certificate living in Eruo
BT
ps.com...
a
1hr
minimum.
-Robert
Staying sharp on the simple things and optical illusions Andrew Gideon Piloting 1 July 5th 07 09:38 PM
Staying current/proficient Kevin Clarke Instrument Flight Rules 21 February 12th 07 04:10 AM
Newbie question: staying calmly behind glider tug [email protected] Soaring 21 September 15th 05 09:19 PM
Is there any way to avoid ice other than staying on the ground? Paul Tomblin Instrument Flight Rules 16 November 8th 04 04:30 PM
military and overseas voting [email protected] Military Aviation 6 September 25th 04 09:25 AM
