Metal cutting bandsaw problem
Old November 7th 07, 05:03 PM posted to rec.aviation.homebuilt
Anthony W
Default Metal cutting bandsaw problem
Anybody here have any experience with one of these critters? I bought a
Jet 1/2 HP last month for cutting aluminum. The saw looks to be of
exceptional quality for being Taiwanese and I'm overall pleased with how
it's made but assembling it was less than fun (getting the legs on was a
bitch...)
My aluminum supplier recommended a 4-6 variable pitch blade but the
closest blade I could was was a 6-8 pitch. Well it cuts like crazy now
rather than loading up but the problem I'm having is the shavings from
cutting get into the wheels of the saw and jam it up. So far I've been
able to blow the shavings away with a stream of air from an air nozzle.
Any one know of a better way to solve this problem or any other tips
for cutting aluminum with this saw?
Tony
Old November 7th 07, 05:17 PM posted to rec.aviation.homebuilt
Maxwell
"Anthony W" wrote in message
news:2llYi.6270$kH.3914@trndny04...
bitch...)
Any one know of a better way to solve this problem or any other tips for
Does it have a recirculating coolant system, or a table that was designed to
drain one?
Old November 7th 07, 05:19 PM posted to rec.aviation.homebuilt
Maxwell
bitch...)
I have also seen small rotary wire brushes (designed for a drill motor or
such) bearing mounted to turn at an angle, rotated by only the passing
blade, but scrubing chips from the blade.
Old November 7th 07, 05:20 PM posted to rec.aviation.homebuilt
Anthony W
drain one?
Nope, it's not that sophisticated.
Tony
Old November 7th 07, 05:27 PM posted to rec.aviation.homebuilt
Maxwell
news:JBlYi.11567$%n.4571@trndny07...
to drain one?
You might consider mounting it in a large metal tray that would catch the
coolant. If you ever cut much steel with it, it can be well worth the
trouble in blade life. But beware of some cutting oils, they can cause the
blade to keep jumping off the cheaper saws. But a water based might do the
trick.
Otherwise, you might try the rotary brush deal. I have seen it used a lot on
verticals for cutting aluminum with just wax.
Old November 7th 07, 06:12 PM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Maxwell" wrote in message
Even less sophisticated would be a couple of toothbrush-size wire brushes
mounted, one on each side of the blade and/or mounted to scrub the debris
off the rubber tires. Harborfreight sells some cheap brass brushes which
work well for this.
Rich S.
Old November 7th 07, 10:18 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"Rich S." wrote in message
work well for this.
That is the approach I have seen on metal bandsaws.
Mount them stationary on the part that adjusts the second guide blocks or
wheels, just past the guides. Mount them to have a little tilt, so that the
first part that gets brushed is the back, and then angling down to the
teeth. This will brush them down off the blades, with gravity helping out.
Old November 8th 07, 12:52 AM posted to rec.aviation.homebuilt
Maxwell
"Morgans" wrote in message
or such) bearing mounted to turn at an angle, rotated by only the
passing blade, but scrubing chips from the blade.
work well for this.
the first part that gets brushed is the back, and then angling down to the
out.
Stationary brushes are ok, but the rotary a lot more robust and run longer
without adjustment.
Old November 8th 07, 10:47 AM posted to rec.aviation.homebuilt
bitch...)
Tony
I just lurk here. Post this on rec.crafts.metalworking where I hang
out.
Karl
Old November 8th 07, 04:34 PM posted to rec.aviation.homebuilt
Anthony W
blade, but scrubbing chips from the blade.
Thanks, That's an interesting idea and I'll look into it. It would also
add the benefit of removing any loading of the blade. The 6-8 pitch
blade doesn't load much but a few chips will stick here and there.
Tony
PLEASE NEED HELP with Cherokee 180 metal bulkhead problem under back seat C Owning 37 April 27th 05 03:00 PM
Cutting Lexan? Scott Home Built 15 February 19th 04 01:51 AM
Cutting shirttails??? Larry Dighera Soaring 11 September 3rd 03 04:34 PM
Cutting off shirt tails Wally Samuelson Military Aviation 24 September 3rd 03 01:33 AM
Cutting shirttails??? Larry Dighera Piloting 1 August 26th 03 07:55 PM
