What belly tank is this in this P-47???
Old November 18th 03, 12:32 PM
Dingo
"Vicente Vazquez" wrote in message
I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank,
but never seen this one ...
http://www.aviacaomilitar.com.br/webkits/hc001.jpg
Just a guess ... is it a ASR inflateable "life raft" ?
John Ding (UK)
Old November 18th 03, 12:53 PM
Vicente Vazquez
Default What belly tank is this in this P-47???
I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank, but
Old November 18th 03, 02:49 PM
MLenoch
Possible a field modified tank. I've not seen this before either. Thx.
VL
Old November 18th 03, 03:22 PM
Kevin Brooks
"Vicente Vazquez" wrote in message ...
Could be either a 200 gallon tank or possibly a cardboard tank:
"Following the early conformal 758 liter (200 US gallon) ferry tank
and the lozenge-shaped flat 758 liter belly tank, teardrop-shaped 284
liter (75 US gallon) and 568 liter (150 US gallon) metal wing drop
tanks were adopted. The P-47 also used British-designed 409 liter (108
US gallon) and 758 liter tanks made of plastic-impregnated paper.
These tanks were cheap and were useless to the enemy if found after
being dropped, though they could not store fuel for an extended period
of time."
www.vectorsite.net/avp47.html
Brooks
Old November 18th 03, 03:37 PM
robert arndt
"Dingo" wrote in message ...
I'm not even going to try and guess... but I will tell you that the
P-47s used many other drop tanks including: 100, 110, even 165 gallon
types... in adition to the napalm ones. Maybe this will lead you to
the right one.
BTW, is the "hc" in the URL refer to a Hobby Craft kit? If so, look up
a HC P-47 kit with drop tank.
Just a suggestion.
Rob
Sorry I couldn't answer your question directly; if it were German drop
tanks the answer would be easy!
Old November 18th 03, 04:36 PM
Steven P. McNicoll
but
My guess is a field modification. A standard 75 gallon tank split at the
joint with a plug inserted.
Old November 18th 03, 09:21 PM
Dale
Looks like one of the ferry tanks that they used.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old November 19th 03, 12:09 AM
Dave Kearton
"robert arndt" escreveu na mensagem
om...
Actually, I used "hc" on the file name referring to the source of the
image,
a book in Portuguese called "Heróis dos Céus", about the Brazilian Fighter
Squadron that fought in Italy. The image of the belly tank is actually
just
a "close up" of part of this image:
http://www.aviacaomilitar.com.br/webkits/hc002.jpg
Vicente
That's an artistic roundel on the plane in the rear.
Cheers
Dave Kearton
Old November 19th 03, 12:58 AM
Vicente Vazquez
om...
Actually, I used "hc" on the file name referring to the source of the image,
Squadron that fought in Italy. The image of the belly tank is actually just
Vicente
Old November 19th 03, 02:37 AM
Vicente Vazquez
"Dave Kearton" escreveu na
mensagem ...
Cheers
Dave Kearton
Nope. That's the Brazilian AF's insignia painted over USAAC's insignia. This
had to be done because of ID problems, inclusing some of our P-47's almost
being attacked by RAF Spitfires in one occasion. When the Brazilian P-47's
arrived at Tarquinia, they had only the Brazilian markings painted on four
positions on the wings and none on the fuselage, as seen in this pictu
http://www.aviacaomilitar.com.br/jam...26777_01_g.jpg
Then, because of these ID problems, it was decided to apply the US "Star and
Bars" following the standart of american P-47's and paint the Brazilian
"Star" over them.
Cheers.
Vicente
fuel tank plumbing pwm Home Built 18 January 27th 05 05:54 AM
Building a gas tank Lou Parker Home Built 11 September 13th 04 10:16 PM
FS: or trade - Scott "Executive II" O2 tank assembly near ATL Mike Patterson Aviation Marketplace 0 January 27th 04 05:07 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
