Damned if it ain't flew. Well sorta. On Tuesday we had chinooks here
in Boulder, so at lunch I snuck over to Scott Carpenter Park (uh huh that guy has a park named after him) and managed 14 flights with the replica Wright 1899 kite before it rendered itself unflyable. This may have been the first flight by a Wright machine in Colorado since 1910. Damage was limited to 3 broken ribs, a broken strut, 2 broken tail supports, and a fabric puncture. Not bad for 2 minutes' worth of flying. Harry Frey Wright Brothers Enterprises Frederick, CO |
wright1902glider wrote:
Damned if it ain't flew. Well sorta. On Tuesday we had chinooks here in Boulder, so at lunch I snuck over to Scott Carpenter Park (uh huh that guy has a park named after him) and managed 14 flights with the replica Wright 1899 kite before it rendered itself unflyable. This may have been the first flight by a Wright machine in Colorado since 1910. Damage was limited to 3 broken ribs, a broken strut, 2 broken tail supports, and a fabric puncture. Not bad for 2 minutes' worth of flying. Harry Frey Wright Brothers Enterprises Frederick, CO Yea, Harry! I'll bet that was as big a thrill as Orville and Wilber had! Congradulations. Richard |
![]() "wright1902glider" wrote in message ... Damned if it ain't flew. Well sorta. Well don't stop there, tell us how it flew. ...like a Cub? Pictures? Vaughn |
Pictures? Vaughn A Cub? Hell, airplanes wouldn't fly that good until Piper invented the... oh, right. No fellas, the Wright 1899 kite was nothing more than a quick and dirty way to see if wing warping was going to work. According to Orville, the wingspan was only 5 feet. The fact that Wilbur (Orv never flew it) was inspired to continue after building this machine is the amazing part. Of the other builders that I've talked to, three characteristics seem common. First, it seems impossible to fly it for more than a minute. If its been done, I've not heard of it. (Supposedly, Tom Crouch of the Smithsonian has managed 50 seconds, but I've never talked with Tom Crouch.) Second, it has almost no roll authority. Get it a little out of shape and its going to roll over and dive into the ground. The same seems true for the Wright gliders and airplanes; very slow in roll. Third, the kite has a nasty habit of becoming classically unstable. By that I mean that it porpoises worse than even the 1903 did, and that's a lot. While the gliders and airplanes had an acceptible pitch range of -2 to +10 degrees AOA, the kite's is much less. When it (not you, it) wants to, it'll start a wild pitch occilation that will go from 30 cycles/min. to about 90 cycles/min. in less than 2 seconds, if it doesn't crash or tear itself abart first. Its very fond of doing the later. Although there are few things more facinating and entertaining than watching a Wright kite takeoff, climb 8 feet, and then proceed to shake itself to smithereens, flinging parts at unsuspecting schoolkids along the way. Sounds pretty cool too. Whapa-whapa whapawhapawhawpwpwpwpwpwpwpwpwpwpwpwwppw BANG! CRUNCH! Fun stuff. Time to go shovel more snow and cook a few more ribs. Harry PS: Photos from 2001 are available at http://hometown.aol.com/wright1902glider/airshow4.html and http://hometown.aol.com/wright1902glider/page3.html |
On Mon, 10 Dec 2007 15:04:03 -0800 (PST), wright1902glider
wrote: Well don't stop there, tell us how it flew. ...like a Cub? Pictures? Vaughn A Cub? Hell, airplanes wouldn't fly that good until Piper invented the... oh, right. No fellas, the Wright 1899 kite was nothing more than a quick and dirty way to see if wing warping was going to work. According to Orville, the wingspan was only 5 feet. The fact that Wilbur (Orv never flew it) was inspired to continue after building this machine is the amazing part. Of the other builders that I've talked to, three characteristics seem common. First, it seems impossible to fly it for more than a minute. If its been done, I've not heard of it. (Supposedly, Tom Crouch of the Smithsonian has managed 50 seconds, but I've never talked with Tom Crouch.) Second, it has almost no roll authority. Get it a little out of shape and its going to roll over and dive into the ground. The same seems true for the Wright gliders and airplanes; very slow in roll. Third, the kite has a nasty habit of becoming classically unstable. By that I mean that it porpoises worse than even the 1903 did, and that's a lot. While the gliders and airplanes had an acceptible pitch range of -2 to +10 degrees AOA, the kite's is much less. When it (not you, it) wants to, it'll start a wild pitch occilation that will go from 30 cycles/min. to about 90 cycles/min. in less than 2 seconds, if it doesn't crash or tear itself abart first. Its very fond of doing the later. Although there are few things more facinating and entertaining than watching a Wright kite takeoff, climb 8 feet, and then proceed to shake itself to smithereens, flinging parts at unsuspecting schoolkids along the way. Sounds pretty cool too. Whapa-whapa whapawhapawhawpwpwpwpwpwpwpwpwpwpwpwwppw BANG! CRUNCH! Fun stuff. Time to go shovel more snow and cook a few more ribs. Harry sounds to me like you have a laminar bubble warbling back and forth on the aerofoil. some bubble trips might be in order to nail that little puppy down and make the ride more stable. you also realise that Old Warden has a flying vintage aircraft from that era that can only be successfully flown at a single airspeed. interesting. Stealth Pilot |
the aerofoil. some bubble trips might be in order to nail that little puppy down and make the ride more stable. you also realise that Old Warden has a flying vintage aircraft from that era that can only be successfully flown at a single airspeed. Yep, This is both a center of pressure issue and an AOA stall issue. They knew about it and finally saw it appear in the metrics from the wind tunnel 2 years later. Of course they didn't know it was a "bubble", they just knew that the C.P. moved in mysterious ways as the AOA was changed, and lift did not build linearly. The airfoil used in the 1899 kite is a flattened parabolic curve, similar to what Chanute, Herring, Avery, & Huffaker, et al. were using. This changed to a modified Plin's curve for 1900 and 1901, and then changed again to the Wright #12 following the wind tunnel tests. Harry |
The new art of thermalling - with a kite... | [email protected] | Soaring | 3 | July 30th 06 04:06 AM |
Kite flying | Skylune | Piloting | 49 | April 23rd 06 04:08 AM |
Long Island Crash - Kite String? | Neb Okla | Rotorcraft | 5 | September 3rd 04 05:43 PM |
Help: PanAm Kite | Ralf Dietrich | General Aviation | 0 | November 22nd 03 12:55 PM |
Gyro Rotor Wing Toy Kite | Tha RagMan | Rotorcraft | 6 | November 11th 03 04:17 PM |
