heat seal or glue?
Old December 11th 07, 11:23 PM posted to rec.aviation.homebuilt
Default heat seal or glue?
I'm working on a project and need some advice. My goal is to find the
cheapest and easiest way to "laminate" two sheets of fabric together
with a sheet of netting sandwhiched in the middle.
Still with me?
For example..
I'll put a yard of ripstop nylon fabric on the table.
Then I'll lay a same size piece of netting down - similar to this but
made of small wire.. http://www.usnetting.com/HTML/all-purpose.html
Finally I'll put a second yard of ripstop nylon down.
Then I want to glue or heat seal all three layers together.
I can use any type of fabric but I'd like the finished product ( all
three layers fused together) to be somewhat water resistant. Also the
fusing method should be easy to do without an expensive machine.
Think epoxy cement or home clothes iron.
The best I can come up with on my own is to use :
Heat Sealable Oxford
200 Denier, 6.5oz/sq yd. This fabric has a special coating that makes
it possible to be heat-sealed, coated side to coated side, using a
household iron. Perfect for dry bags, spray skirts and all water
sports for which you need a waterproof bag.
Width: 58"
Colors: Nickel Gray, Yellow, Royal, Red, Fl. Orange, Black
$13.25/yd
The netting I'll be using will be thin and will form roughly 1inch by
1inch squares. It should be tough enough to withstand heat or
epoxy.
Anybody have any other ideas? If I used glue I'd be able to use
cheaper fabric.
Jay
Old December 14th 07, 06:39 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
http://www.dritz.com/brands/showcase...ITEM_NUM=11079
won't work with nylon - the nylon will melt before the fusible
material will.
spray adhesive - the grade they use for vinyl tops - should do it, and
will give you more latitude in the fabric you can use. 3M 8090 is the
absolute shizz, but it's spendy. Almost any brand or grade of spray
adhesive, applied to BOTH surfaces should work.
prop seal Jim Burns Owning 11 July 23rd 05 03:59 AM
Door seal?? Frode Berg Owning 1 June 14th 04 03:28 PM
becoming a gold-seal instructor Baron Man Piloting 3 January 9th 04 01:15 PM
Window seal Hankal Owning 1 December 22nd 03 12:33 AM
Crank Seal? Mark S Conway Owning 3 November 10th 03 04:29 AM
