Brake bleeder device
Old December 12th 07, 04:56 AM posted to rec.aviation.homebuilt
Steve S.
Default Brake bleeder device
Folks--
This is really something I should know and I am a little embarrassed
that I don't. The topic is brake bleeders. Not the fill fitting on
the bottom of the calipers, but rather the device one uses to push
brake fluid uphill into the system (I fill from the bottom up, which
works very well for this plane).
Until recently I used a little squirt gun contraption that several of
us cobbled together. It never worked to full satisfaction but I
grunted through. During the last fill cycle I broke our little squirt
gun and a guy on our field hauled out his own homemade filler to save
the day.
He had a pressure sprayer (the sort of plastic pump-up pressure pot
item that one often sees used to dispense weed killer or pesticides,
etc) with a fitting on the end that attached to the bleeder fitting.
Super simple, super effective.
He has gone to Florida for the winter so A) I can't borrow his any
longer or B) ask him the particulars of his device. So I'm asking
you.
One guy on the field is hypothesizing that the key element of the
device (the fitting that attached to the bleeder valve) is nothing
more than a fitting for a grease gun. This is very plausible but I'm
not sure. The geometry looks pretty close.
Another guy is fairly sure the fitting in question is an Aircraft
Spruce (or Wicks, or WAG Aero) part that is specific for the purpose.
In the Spruce catalog it is P/N 87-5, Cleveland Brake Line Bleeder.
Which of course begs the question of whether or not it is only for
Cleveland fittings. Can't tell from the line drawing. It does not
look the same as the one my guy on the field had.
And yes Spruce also sells the whole assembly in one go but it is
nearly $70 plus shipping, whereas I can get the constituent parts for
less than $15 if the fitting is generic.
So, what's the fitting?
Thanks in advance, and stay safe.
Steve.
Old December 12th 07, 07:08 AM posted to rec.aviation.homebuilt
I use an oiler squirt can I got from ACE(?) hardware. Attached some
tubing to the squirt end and manage to get all the bubbles out. A
little messy but it works. I really don't need to bleed it that often.
SQ2000 canard http://www.abri.com/sq2000
Old December 12th 07, 02:19 PM posted to rec.aviation.homebuilt
comanche driver
mine is a chunk of 4 inch pvc with a cap glued on one end and a screw plug
in the other. a tire valve stem is mounted in the cap. a hole is drilled
and tapped in the side of the tube at the bottom and a small brass valve is
inserted. a small tube that fits over the bleeder screw is attached to the
valve. fill the pvc tube with 5606 screw the cap on, charge it to about 30
psi with the compressor, slip the tube over the fitting, crack the bleeder
fitting and open the valve slightly.....vola
cost about 3 bucks.......
R. burns
Some New Benefits of GPS Device [email protected] Piloting 0 September 19th 07 11:09 AM
Tiedown "winch" device City Dweller Owning 12 June 22nd 05 05:37 PM
New Wheel Locking Device TM Products 2 March 29th 05 04:07 PM
DIY DF device John Home Built 15 May 4th 04 11:32 PM
New traffic warning device Loran Products 26 February 18th 04 12:14 AM
