Wood Laminations and Springback
Old January 24th 08, 03:24 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Bertie the Bunyip
Default Wood Laminations and Springback
On 24 Jan, 00:29, "Kyle Boatright" wrote:
I'm working on the center section for a Hatz. *The trailing edge of the
center section is a recurved lamination that provides better access to the
front cockpit.
I've steamed and clamped the strips into a form, and they have taken on some
of the curve, but when I unclamp 'em after they dry, I get significant
springback. *The question is whether I need to allow for this in the
finished lamination, or whether the springback will go away when I glue up
the assembly?
FYI, the lamination starts as four 3" x 1/4" strips.
Thanks in advance,
Just did my first laminations a few months ago. They didn't spring at
all once they were glued up.
Bertie
Old January 24th 08, 05:33 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Morgans[_2_]
Just curious, to see how your experience stacks up with laminations I have
done.
What was the minimum radius for your laminations, approximately?
Old January 24th 08, 02:41 PM posted to rec.aviation.homebuilt
Bertie the Bunyip[_22_]
"Morgans" wrote in
have
done.
hmm, good question. I haven't done the center section yet, which is laid up
according to a couple of arcs. Only the tips and they kind of spiral out. I
would guess a bit under a foot radius. I steamed them first, of course. I
just used some PVC drainpipe, made a couple of plywood plugs for th eends
and plugged a domestic steam cleaner into it for 20 minutes and they were
like spaghetti. I used Areodux for the glue and they were solid as rocks
when I took 'em out.
Since that was my first stab at laminating, I tried it with some scrap pine
I ripped up first.
Bertie
Wood Laminations and Springback Kyle Boatright Home Built 6 January 25th 08 01:28 PM
Wood Laminations and Springback Kyle Boatright Piloting 3 January 24th 08 05:33 AM
wood species question Stewart Glenn Home Built 78 August 11th 05 07:42 AM
Installing a wood prop... SteveR Home Built 19 July 24th 05 07:42 AM
Using Balsa wood Lou Parker Home Built 10 December 8th 03 06:08 PM
