Aerodynamic question for you engineers
Old January 25th 08, 07:22 AM posted to rec.aviation.piloting
Pete Brown
Default Aerodynamic question for you engineers
If a conventional aircraft is in stable level flight and the stick is
pulled back, all of the texts I have read indicate that the aircraft
pitches up, rotating through the CG.
Is this exactly correct or is it a very useful approximation good for
all practical purposes?
Most aircraft have the CG located slightly forward of the center of
pressure ( CP or center of lift) for positive pitch stability. I was
wondering if the actual point of rotation is displaced somewhat aft of
the CG, someplace close to the CG but in fact some small distance
towards the CP.
When the aircraft is subject only to the force of gravity, any
displacement will cause it to rotate around the cg but in flight its
subject to gravity as well as the aerodynamic forces which act through
the CP, suggesting to me that the point of rotation is not quite on the CG.
Thanks
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Going home after a long day
http://farm2.static.flickr.com/1415/...22928754_b.jpg
The fleet at Summit. Mt. McKinley is about 45nm away at 20,320 msl.
http://farm1.static.flickr.com/187/4...cb8d2482_b.jpg
The 170B at Bold near Eklutna Glacier
http://farm1.static.flickr.com/168/4...a216d7bb75.jpg
Old January 25th 08, 01:43 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 24 Jan 2008 21:22:23 -0900, Pete Brown wrote in
towards the CP.
That's an interesting question. I hadn't thought about it before.
First let me say, that I'm not an aeronautical engineer, but
intuitively I figure it this way.
In stable, level flight lift (acting through the center of pressure) =
weight (acting through the center of gravity), so it would seem that a
downward force on the tail would cause the aircraft to rotate on its
lateral axis through a point midway between the center of
lift/pressure and center of gravity. But that's a guess, and it
doesn't consider the displacement of the center of pressure forward
with the increase in angle of attack.
Old January 25th 08, 03:17 PM posted to rec.aviation.piloting
D Ramapriya
towards the CP.
It's tempting to think that it could be somewhere near the center of
the balance arm but it's hard to logically argue against the CG, isn't
it?
Ramapriya
[not an aero engineer]
Old January 25th 08, 04:19 PM posted to rec.aviation.piloting
Bertie the Bunyip[_22_]
D Ramapriya wrote in
of the CG, someplace close to the CG but in fact some small distance
towards the CP.
through the CP, suggesting to me that the point of rotation is not
quite on the CG.
it?
They're the same thing.
Bertie
Old January 25th 08, 05:02 PM posted to rec.aviation.piloting
D Ramapriya
towards the CP.
quite on the CG.
it?
By balance arm, I meant the distance between CG and CP. Missing
something, am I?
Ramapriya
Old January 25th 08, 05:29 PM posted to rec.aviation.piloting
D Ramapriya wrote
innews:8e2786b5-d92c-4fb3-b950-2d9346494a87@
1g2000hsl.googlegroups.com
is pulled back, all of the texts I have read indicate that the
aircraft pitches up, rotating through the CG.
for all practical purposes?
of pressure ( CP or center of lift) for positive pitch stability.
I was wondering if the actual point of rotation is displaced
somewhat aft of the CG, someplace close to the CG but in fact some
small distance towards the CP.
its subject to gravity as well as the aerodynamic forces which act
quite on the CG.
of the balance arm but it's hard to logically argue against the CG,
isn't it?
something, am I?
Well, that'd be a misdefinition. Also, CP really should read CL
Bertie
Old January 25th 08, 05:42 PM posted to rec.aviation.piloting
D Ramapriya
isn't it?
something, am I?
Bertie
But we need some term for what I referred to as the balance arm, i.e.
the distance between CG and CL (CP).
Ramapriya
Old January 25th 08, 06:10 PM posted to rec.aviation.piloting
D Ramapriya wrote
m:
center of the balance arm but it's hard to logically argue
against the CG, isn't it?
something, am I?
Bertie
No we don't, you just defined it.
Bertie
Old January 25th 08, 06:26 PM posted to rec.aviation.piloting
D Ramapriya
something, am I?
Bertie
Bertie
Are you saying that CG and CL are the same? I definitely remember
reading that they're different.
Ramapriya
a question for the aeronautical engineers among us Tina Piloting 10 November 4th 07 01:56 PM
Are flight engineers qualified to fly? Mxsmanic Piloting 14 January 23rd 07 08:39 PM
Aerodynamic Drag Kyle Boatright Home Built 7 September 26th 05 04:34 AM
Aerodynamic Simulation of Standard Cirrus Glider Jim Hendrix Soaring 13 November 10th 04 12:38 AM
Airfoil aerodynamic simulator... Thomas J. Paladino Jr. Piloting 4 May 17th 04 03:41 PM
