l'Hotellier on EB28
Old January 26th 08, 08:29 PM posted to rec.aviation.soaring
rlovinggood
Default l'Hotellier on EB28
The first edition of the new magazine, "Gliding International" has an
article on the 2 seat self-launch super glider, the EB28. I would
have thought that a glider of this class would have automatic hookups,
but it uses l'Hotellier connections.
Do other current design open class ships use automatic connections?
eta
Duo-Discus X
Nimbus 4
ASH-25
ASH-31 (isn't that the next big two seater from Poppenhausen?)
Antares
DG-1000
For a price of 'only' Euro 212,000 plus VAT, I would have expected
auto connections.
Ray Lovinggood
Carrboro, North Carolina, USA
Old January 26th 08, 08:50 PM posted to rec.aviation.soaring
eta
Duo-Discus X
Nimbus 4
ASH-25
Antares
DG-1000
auto connections.
Ray Lovinggood
Antares 18T has all automatic connections. Antares 20E has all
automatic connections except for the two plugs that connect the
batteries in the wings to the fuselage. You're not going anywhere
if you forget those ;-)
Old January 27th 08, 01:14 AM posted to rec.aviation.soaring
article on the 2 seat self-launch super glider, the EB28. �I would
Ray, I believe the EB 28 is a derivitive of the ASH-25. Perhaps the
ASH-25 was designed berfore
automatic hook ups became popular.
Robert Mudd
Moriarty, New Mexico
Old January 27th 08, 07:55 AM posted to rec.aviation.soaring
Bruce
Depends which EB28 you are discussing.
The original EB28s used a ASH25 fuselage and inner wing panel, with
modifications to the outer wings and to add a Binder self launch powerplant.
Latest version uses an Eta fuselage and the wing evolution has also apparently
continued although I don't know the details.
Presumably the connection types depend on the version of fuselage you have,
with the wing stub ends being made accordingly?
Robert Mudd
Old January 27th 08, 09:12 AM posted to rec.aviation.soaring
Cats
On Jan 27, 12:14Â*am, "
The ASH25 I helped rig a couple of times had hotelliers, not automatic
connections, for the wings. I don't know about the tailplane - I'm
not tall enough to reach. It also had non-automatic connections
between the outer and inner wing panels.
Old January 27th 08, 12:32 PM posted to rec.aviation.soaring
Erik Braun
eta
I don't know about this one.
Duo-Discus X
The Duo X, XL and earlier versions all have automatic Hänle connections.
Nimbus 4
At least the single seater version uses Hotellier hookups.
ASH-25
Also no automatic hookups, but Hotellier.
You mean the ASH-30, which will have automatic Hänle connections on the
inner wing. It seems to be difficult to build them into the outer wing,
though.
http://www.alexander-schleicher.de/p...ash30_main.htm
Antares
has automatic Hänle connections.
DG-1000
uses automatic connections, too, but of a different kind. It's a torsion
linkage, to which I can't find any pictures at the moment. DG has used them
for some time, though. I think, the DG-500 has the same ones built in.
Erik Braun,
Akaflieg Karlsruhe,
South-West Germany.
Stolen EB28 - please help catch the thieves David Starer Soaring 0 December 20th 07 07:37 PM
EB28 Electronic Turbulators phil collin Soaring 3 August 5th 06 09:47 PM
Hints on Securing L'Hotellier with Wedekind Sleeves ContestID67 Soaring 0 December 1st 05 09:29 PM
L'Hotellier [email protected] Soaring 5 September 9th 05 05:21 PM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 04:05 AM
