SPOT
Old February 5th 08, 01:39 AM posted to rec.aviation.homebuilt
D.Rizzato
Default SPOT
Hi Folks
Before you purchase SPOT for you airplane please be aware of the following.
If your unit is defective even from the first day of purchase you will have to send
it back to them, they will also charge you for the return shipping.
You may get a return authorization with in 72 hours you may
not see your SPOT for a couple of weeks.
Please spread this around before someone get in trouble because of the false
security portrayed by SPOT.
The following is a report from COPA Canadian Owner & Pilot Association
Thank you for this report. This is the third one I have received that
SPOT does not work when received. Most people would expect
to return it to the point of purchase for replacement.
It seems strange that they are putting signs about
defective units in the package - you would think they would
test them before they are sent. It should not be a case of
being damaged in shipping - they are supposed to be
built for rugged conditions.
I have copied the manager at Globalstar so he is aware
of this problem, which appears to be more than a
minor one judging by the reports I have received.
Regarding SPOT being a replacement for an ELT,
please see my most recent update on our web site.
Transport Canada has done an about face on
the issue and it looks like we will all have to equip with an ELT.
SPOT GPS jeplane Soaring 17 February 5th 08 06:23 AM
SPOT D.Rizzato General Aviation 0 February 5th 08 02:04 AM
SPOT D.Rizzato Piloting 0 February 5th 08 01:42 AM
SPOT D.Rizzato Owning 0 February 5th 08 01:42 AM
Soaring with SPOT 5Z Soaring 14 January 10th 08 01:56 AM
