Why so expensive (flight recorders)
Old February 15th 08, 02:58 PM posted to rec.aviation.soaring
Jim Beckman
Default Why so expensive (flight recorders)
A simple (EW Microrecorder) is under $800. In todays
money, an extra $20 for a badge flight is less than
the round of beers you buy. 40 badge flights and you
can buy a second one. Pretty soon, you hold a club
meeting to decide what to buy next once there are
enough
recorders.
Again you're making the wrong comparison. The point
is that a Garmin Etrex costs a tenth of that, and can
provide just as secure a record for badge flights.
It's not much for navigation, but it will tell you
how far away you are from where you're going, and what
your ground speed is. Surely a Silver Badge attempt
doesn't require moving map capabilities, or extensive
computation power. There's something to be said for
encouraging the new XC pilot to keep his head up out
of the cockpit.
Sounds like P3 is making good progress on making this
all accepted.
Jim Beckman
Standalone Flight Recorders for Club Use ContestID67 Soaring 8 April 24th 07 02:27 AM
Amendment 9 to the Technical Specification for IGC Flight Recorders Ian Strachan Soaring 0 July 1st 06 07:50 PM
IGC-approval levels for some types of Flight Recorders Ian Strachan Soaring 42 March 19th 05 06:42 PM
Commercial - Mounts for GPS Flight Recorders Paul Remde Soaring 0 March 13th 04 03:03 PM
Approved IGC Flight recorders mat Redsell Soaring 2 March 5th 04 04:35 PM
