Baffling . . . stuffing . . .
Old March 1st 08, 04:35 AM posted to rec.aviation.homebuilt
Steve S.
Default Baffling . . . stuffing . . .
Folks:
I am in the process of sealing up a plenum project. So far all has
gone well using regular baffle seal and silicone P strip.
However there are several places of extremely irregular shape that I
cannot seal with the baffle seal or P strip. Some of the guys around
my field have advised that the tricks of the trade are to stuff the
tough spots with either dry fiberglass cloth or steel wool.
I am not thrilled with either trick, although I concede that they
would work.
The dry glass cloth is going to be difficult to secure in place and
frankly would look like a bunch of rags stuffed into the crevices of
an otherwise nice installation. The steel wool is, well, steel wool.
In no time it is going to be corroded and nasty and it is obviously a
bit on the abrasive side. And I don't think it would seal very well,
to boot.
So I'm looking for suggestions of something I can stuff into an oddly
shaped hole in contact with the cooling fins on an engine. I like the
idea of silicone foam as it will take the heat and it's very
conformable, but before I spend the big bucks I thought I would cast a
wider net to see if there is a simple trick that I have not thought
of.
Thanks in advance and take care--
Steve.
Old March 1st 08, 04:39 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Steve S. wrote:
Folks:
would work.
to boot.
of.
Steve.
Post some photos.
Let's see what we are actually looking at first...
Old March 2nd 08, 12:48 AM posted to rec.aviation.homebuilt
On Feb 29, 9:35 pm, "Steve S." wrote:
Folks:
would work.
to boot.
of.
Steve.
You can close off just about any odd hole if you carefully cut
baffle strip or aluminum sheet to fit the opening. Stuffing
miscellaneous junk into places like that is ugly and can cause trouble
if it gets out and into or onto places where it doesn't belong.
Watch the silicone foam. If it sticks to a large area of the
head or cylinder it might cause a hot spot by keeping the air off it.
Dan
Engine Baffling Supplier Mike Spera Owning 6 January 25th 08 12:02 AM
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? jls Home Built 3 February 3rd 04 12:15 AM
