Got Pilot Heat?
Old April 4th 08, 04:12 AM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
Default Got Pilot Heat?
http://www.internationalferryflights...ot%20Pilot.JPG
Description Of Aircraft From Seller,
http://www.dieselairplanes.com/news.html
http://www.dieselairplanes.com/products.html
More Photos Of The Better Than New 182,
http://www.internationalferryflights...el/Folder%202/
Old April 4th 08, 04:57 AM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
Michael Ash
Jeez, if that's better than new, I'd hate to have seen it when it rolled
off the assembly line.
Michael Ash
Rogue Amoeba Software
Old April 4th 08, 06:36 PM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
Robert M. Gary
Honestly, I'm sure all of us on the list would be embarrased if
someone took pictures that close of our plane. While we may think our
planes are perfect, everyone has small cracks, etc that can only be
seen up close. The plane in question may be better than new in that it
may be better equipped than when it rolled out of the factory. Even a
really hot model wouldn't want extreme close up photos of her posted.
-Robert
Old April 4th 08, 08:16 PM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
-Robert
Yea, but when some one is spending 300K
And Aircraft Is Described As,
"Your plane will look as good as a new plane: After a full corrosion
inspection, it receives a new paint, a new interior and trims, the
avionics of your choice, and new, simplified instruments and controls
as per the SMA kit."
FAA has Tagged 8620-1 the Plane due to condition of Prop Hub and a few
other major hidden things!
Old April 4th 08, 08:36 PM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
Robert M. Gary
Damn, that's one hell of a 182!
-Robert
Old April 5th 08, 05:44 PM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
-Robert
Those Cessna plastic fairings shrink with age and the heat and UV of
the sun, and contract in the cold, and they will crack after a while.
Very difficult to repair, and they'll only crack again anyway.
Expensive from Cessna. Stene Aviation has fiberglass replacements for
most of them, and we've had really good success over the years with
their stuff. Much stronger than the plastic, no heavier (made
thinner), and easily repaired if they do get damaged. One thing: Got
to watch anyplace that moves, like the gear leg at the fuselage; the
fiberglass will cut into the leg's aluminum fairing. Put some felt or
poly chafe tape on the leg under it.
See http://www.steneaviation.com/
Dan
Old April 5th 08, 07:37 PM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
Well, there is an 8620 hanging on the plane as of yesterday! FAA says
Once through the Shot Penning it is not airworthy. They found no signs
of rubbing around the area near the hub.
Another Couple Photos of Prop Hub,
http://www.internationalferryflights...op%20Hub_1.jpg
http://www.internationalferryflights...op%20Hub_2.jpg
Belt Hidden Behind Baffling Hard To See.
http://www.internationalferryflights...202/Belt_1.jpg
8620, Grounded! Not Only By My Word the Faa
http://www.internationalferryflights...0_Grounded.jpg
Old April 8th 08, 08:32 PM posted to rec.aviation.owning,rec.aviation.student,rec.aviation.ifr
Steve Foley
Who called the feds?
Got Pilot Heat? [email protected] Owning 7 April 8th 08 08:32 PM
But it's a dry heat.... Casey Wilson Piloting 31 July 23rd 05 10:09 PM
Pre-Heat at BED? Colin W Kingsbury Owning 7 January 21st 05 02:25 AM
auxiliary heat Jim Burns Owning 15 October 20th 04 09:08 PM
Pitot heat Paul Mennen Owning 10 November 6th 03 09:54 AM
