Latch repair on Cobra trailer
Old April 8th 08, 12:17 AM posted to rec.aviation.soaring
Tuno
Default Latch repair on Cobra trailer
I've managed to do minor damage to my new Cobra trailer already
One of the clamshell latches snagged on something during ground
maneuvering and pulled hard enough to pop the bottom rivet. Upon
closer inspection, I found the factory used a bolt for the top, which
held firm, but I cannot replace the broken rivet with a bolt because
there is no way to get a nut on it, and there is not room on the
inside of the trailer for machine screw head or nut because of the
tailgate clearance (less than 2mm).
The rivet itself left a hole too big for the 3/16" rivets I tried to
use. It looks like it would take a 1/4" rivet but I cannot find those
anywhere.
Any ideas on how I might re-fasten the bottom of that latch plate?
2NO
Old April 8th 08, 01:01 AM posted to rec.aviation.soaring
Bob Kuykendall
I'd use a rivnut or a nutsert:
http://www.aircraftspruce.com/catalo...es/rivnuts.php
http://www.aircraftspruce.com/catalo...s/nutserts.php
Thanks, Bob K.
Old April 8th 08, 02:21 AM posted to rec.aviation.soaring
Rex
Call me at Williams Soaring Center
530 473 5600
I will send you a 5mm rivet, No Charge
Rex Mayes
Cobra Trailer - U.S. Axle? Mitch Soaring 8 March 2nd 07 10:16 PM
Cobra Trailer [email protected] Soaring 22 December 8th 06 12:38 AM
Cobra Trailer brakes R Barry Soaring 22 July 19th 04 05:51 PM
Cobra Trailer Soaring 1 September 28th 03 02:14 PM
FS: Cobra Trailer Ed Byars Soaring 0 September 22nd 03 05:47 PM
