2 glass HUD question
Old January 30th 04, 03:22 AM
Jim Yanik
Default 2 glass HUD question
Alan Dicey wrote in
B2431 wrote:
I notice some HUDs have 2 glasses. How does this work without
reflections from the second one and interferance from the first?
Dan, U. S. Air Force, retired
Put simply, a dual combiner increases the vertical field of view of
the HUD symbology.
The sheets of glass in front of the pilot are called combiners: they
combine the HUD display symbology (projected from beneath by a very
bright CRT and some big lenses) with the pilots forward view by
reflecting the symbols projected from a very bright CRT under the
glareshield.
http://www.cmcelectronics.ca/En/Prod...hud_nthawk_faq
_en.html
http://www.mikesflightdeck.com/head_up_displays.htm
The combiners are cleverly-engineered partial reflectors. The
simplest design is just a semi-silvered mirror. The pilots view of
the outside world is dimmed a little, but the HUD symbology is
overlaid onto the pilots Field of View (FoV), reflected from below.
More advanced combiners use dichroic coatings to partially reflect
only the narrow set of wavelengths emitted by the (usually green) crt
tube. All other light is passed straight through, resulting in a
brighter real-world view (important in bad weather, dusk or night
operations).
The surfaces that are not meant to reflect are given anti-reflection
coatings to minimise the ghost images.
From the pilots point of view, the two combiners are one on top of
other, hence the increase in the vertical FoV. A single combiner
would need too much space above the glareshield and behind the
windscreen, and need a truly enormous final condensing lens in the CRT
projection optics.
I wonder if LCD projection optics will replace the vacuum tube CRT?
And maybe LEDs for a light source?
Jim Yanik
jyanik-at-kua.net
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 05:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Question Charles S Home Built 4 April 5th 04 10:10 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 07:05 PM
