Canard or Mooney
Old May 3rd 08, 06:35 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Linton Yarbrough
Default Canard or Mooney
I don't get the reason for the Cozy or the Velocity (which isn't selling
anyway) from the standpoint of speed, comfort, etc. The $$$ come out the
same for the most part and you don't have composite issues or trouble
getting things fixed. Pusher/tractor preferences aside, am I missing
something that would or does make one of the canards a better purchase?
Old May 4th 08, 05:12 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Stealth Pilot[_2_]
On Sat, 3 May 2008 12:35:13 -0400, Linton Yarbrough
not necessarily.
you only get the performance figures *after* you've built the design
and flown it.
aviation is littered with designs that looked promising but werent.
Stealth Pilot
Old May 5th 08, 02:50 AM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Dave S
Linton Yarbrough wrote:
To make matters worser, I can't build one so I have to take someone
else's work. but the numbers of successful Cozys is a testament to
the design. plus, you get to install a rotary-Wankel; this is good?
The Cozy and the velocity were designed and intended to be used with a
"certified" horizontally opposed air cooled engine. Some enterprising
experimenters have used the rotary/wankel engine, with varying degrees
of success.
Dave
Old May 5th 08, 02:58 AM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Dave S
Peter Dohm wrote:
But the one builder that I knew
who actually started flying a Wankel powered Cozy MkIV finally gave up and
switched to a Lycoming O-360. From what I have heard, he was unsuccessful
at cooling the Wankel; but the Lycoming is running without problems.
That was Buly Aliev.. He was ready to FLY not to keep troubleshooting.
Cooling is a critical issue in a pusher, and you have to make changes
from stock cowling to really cool a wankel properly
John Slade has been flying his for 2 years or so, and while not perfect
is doing pretty good. www.canardaviation.com is his page. There is a
forum to be linked to from there as well.
Another forum, run by Jon Matcho (building, not flying) is Canardzone at
www.canardzone.com
If you are truly interested in rotary engines, check out Tracy Crook's
website, at www.rotaryaviation.com. There are two rotary listservs...
One is moderated and EDITED by Paul Lamar, an afficianado engineer who
has not yet built nor flown a rotary powered aircraft, and tends to be
more theory than practice, but highly technical at times. I unsubscribed
from his list years ago and haven't missed much; folks who disagree with
his findings are summarily dismissed.
The other is The FlyRotary listserv where you will find the majority of
folks who are building or have successfully started and flown homebuilt
rotary aircraft. www.flyrotary.com All are welcome. Webbased archives
available.
Dave
Old May 5th 08, 09:26 AM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.homebuilt
Gezellig[_2_]
on 5/4/2008, Peter Dohm supposed :
not necessarily.
and flown it.
Stealth Pilot
I dunno. For an assortment of reasons, I have not been hanging around the
local airport for the past couple of years. But the one builder that I knew
switched to a Lycoming O-360. From what I have heard, he was unsuccessful at
The only recommendations that I can make are to look/ask on
rec.aviation.homebuilt and also on the canard forum. (I have forgoten what
the canard forum is really called and/or where it is located, but someone on
R.A.H will be sure to know.)
Peter
Lint, my ex-brother-in-law has a Cozy IV and it is a super flight. He
bought his already built and has never had a problem except with the
front nose gear. The faster LD speeds! I think the Cozys are for those
who want to build, the Mooneys for those who don't care to.
Old May 5th 08, 09:28 AM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.homebuilt
clint
a Ruski!
Dave S has brought this to us :
Old May 5th 08, 03:34 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Peter Dohm
"Dave S" wrote in message
and switched to a Lycoming O-360. From what I have heard, he was
unsuccessful at cooling the Wankel; but the Lycoming is running without
problems.
Cooling is a critical issue in a pusher, and you have to make changes from
John Slade has been flying his for 2 years or so, and while not perfect is
doing pretty good. www.canardaviation.com is his page. There is a forum to
www.canardzone.com
One is moderated and EDITED by Paul Lamar, an afficianado engineer who has
not yet built nor flown a rotary powered aircraft, and tends to be more
theory than practice, but highly technical at times. I unsubscribed from
his list years ago and haven't missed much; folks who disagree with his
available.
Dave
Yes, that's true; www.canardaviation.com snd www.canardzone.com are the
sites I was thinking of.
Peter
Old May 5th 08, 03:37 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.homebuilt
Peter Dohm
"clint" wrote in message ...
a Ruski!
Not exactly, but trivial. OTOH, he is/was a contributor to the fuel price
watch system which does seem important...
Peter
Old May 6th 08, 12:04 AM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Gezellig" wrote in message
bought his already built and has never had a problem except with the front
nose gear. The faster LD speeds! I think the Cozys are for those who want
Bingo
Geoff
Old May 6th 08, 08:51 AM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Linton
Dave S explained on 5/4/2008 :
experimenters have used the rotary/wankel engine, with varying degrees of
success.
Dave
Dave I don't need varying degrees of success. I guess as the Capt said
if you want to tinker, maintain and build, then go EXP.
Maybe my next assessment is Mooney vs. ???
canard flying boat Darrel Toepfer Home Built 14 October 19th 15 08:37 AM
My first four flights on an RJ.03 IBIS canard Hans Home Built 3 August 25th 07 07:43 PM
Aircraft ID? canard biz plane Ron Hardin General Aviation 5 October 1st 06 10:55 PM
Canard nose pading Paul Lee Home Built 6 January 9th 04 08:36 AM
Dumb Canard Question. Russell Kent Home Built 39 October 19th 03 04:25 PM
