LX 1600 and gps
Old May 10th 08, 05:59 PM posted to rec.aviation.soaring
Mark Jardini
Default LX 1600 and gps
Has anyone been successful hooking a GPS engine up with an LX 1600
through the port where a Colibri would go? That would be with the GPS
engine spliced to an RJ6 flat cable. That port should supply 12v to
the GPS antenna.
I am so far utterly defeated, trying to use a Garmin 18 PC.
Any tips or tricks encountered on your road to success would be much
appreciated.
Lost in th electronic woods.
Mark
Apis MC
Old May 10th 08, 11:09 PM posted to rec.aviation.soaring
Paul Remde
Hi Mark,
I see that the Garmin 18 PC has 12V power input by using a cigarette lighter
power converter. My guess is that the unit is actually powered by a lower
voltage. Are you using the cigarette lighter voltage reducer?
I don't know whether the Colibri connector will work. Since it connects to
the Colibri's only RS-232 port, I can't think of any reason why it wouldn't
work.
I recommend using the standard GPS input connector rather than the Colibri
connector.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Mark Jardini" wrote in message
the GPS antenna.
appreciated.
Mark
Apis MC
British Airways Concorde (1600 x 1200) (1/3) Elmo von Thud Aviation Photos 5 August 23rd 07 05:48 AM
British Airways Concorde (1600 x 1200) (2/3) Elmo von Thud Aviation Photos 0 August 19th 07 04:40 AM
Questions about LX 1600 [email protected] Soaring 1 August 21st 06 01:58 PM
Lx 1600 vs Borgelt 50 Glen Kelley Soaring 7 March 27th 05 07:18 PM
prop for 1600 cc VW dave Home Built 1 August 12th 04 06:57 AM
