Wing Leading Edge Refinishing
Old June 16th 08, 10:28 AM posted to rec.aviation.soaring
Jan Eldem[_2_]
Default Wing Leading Edge Refinishing
HI all,
My Pegasus was refinished in Poland a few years ago in two pack poly
paint, seemed to do a good job I thought. but after a while the very tip
of the leading edge has started to get vertical cracks showing where the
wing flexes (peg's have very bendy wings)
The rest of the wing is fine, so after a bit of a look with some wet and
dry it seems that they have just flatted the gelcoat back on the leading
edge and sprayed over it !! I guess they did that as a easy way to keep
the wings profile correct???
everywhere else had the gel removed apart from the L/E
My problem is,
I want to refinish the leading edge, how do I go about keeping the profile
correct and am I best to go back to glass on the affected areas
any ideas and suggestions would be great !!
Regards and thanks for the help
Jan
Old June 16th 08, 03:21 PM posted to rec.aviation.soaring
Udo
Rather then sanding the leading edge of the wing all at once,
sand 2 ft sections and leaving a couple of inches of leading edge
untouched. Build up the sanded section using the remaining old leading
edge as a guide. Remove the 2 inches that were left behind and use
the new build up section again as guide.
Udo
On Jun 16, 4:28*am, Jan Eldem wrote:
HI all,
paint, seemed to do a good job I thought. *but after a while the very tip
edge and sprayed over it !! *I guess they did that as a easy way to keep
My problem is,
Jan
Old June 16th 08, 03:33 PM posted to rec.aviation.soaring
Michael Huber
If you can get the original airfoil coordinates it is quite simple to make
templates on a cnc router. Many modelers have suitable cnc routers already
and might be cheaper than a professional shop.
Michael
Old June 16th 08, 08:58 PM posted to rec.aviation.soaring
Robert Gaines[_2_]
profile
make
already
Michael
The original airfoil design and the resulting profile when produced at
the factory probably are not the same. They may be reasonably close but I
have seen large differences between left and righ wing airfoils on
relatively new sailplanes. And these sailplanes were among the winning
designs.
Go figure.
Bob
Old June 17th 08, 03:40 PM posted to rec.aviation.soaring
Michael Huber
Sounds to me like one more reason to start with templates of the original
airfoil. Or would you prefer to rely on the profile not replicated exactly
by the manufacturer and later modified by a refinish shop that produced less
than perfect results?
As the original poster is talking about refinishing the leading edge only
differences shouldn´t be that large.
Michael
Propeller leading edge protective tape Sammy Products 0 July 6th 04 01:08 PM
Propeller leading edge protection Sammy Aviation Marketplace 0 July 6th 04 01:07 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 03:45 AM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 01:27 AM
leading edge flaps Arquebus257WeaMag Military Aviation 105 January 14th 04 05:11 AM
