Here's a question for the trolls and flight simmers
Old June 19th 08, 03:49 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
Default Here's a question for the trolls and flight simmers
I know we beat on you guys a lot here but here is a serious question
for you to explore.
scenario: you are flying along on a bright sunny day with no cloud
cover. your wingspan is about 20 ft, fuselage length 14ft and
tailplane about 8ft span. your altitude is 4,500ft.
you look down below you in the exact opposite direction to the sun.
what do you see below you scooting along the ground below you?
is it a sharply defined shadow of your aircraft?
a fuzzy indistinct shadow of your aeroplane?
or what?
it is quite distinct and you can pick it from nearly a mile away.
.....now pilots dont tell them. these guys are actually quite
intelligent but not in' hands on' aviation matters. they should be
able to work this out.
John Gribbin's book 'Science - A History' contains a neat explanation
in the discussion of Fresnel's model of light on p408.
Stealth Pilot
Old June 25th 08, 02:43 PM posted to rec.aviation.piloting
Mike[_22_]
"Stealth Pilot" wrote in message
for you to explore.
or what?
In the grand scheme of "hands on aviation matters", how many beans are in
this hill?
Old June 25th 08, 04:13 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
for you to explore.
or what?
this hill?
I notice that there are no attempts at an answer.
Old June 25th 08, 04:46 PM posted to rec.aviation.piloting
alexy
for you to explore.
or what?
this hill?
Well, you directed the question to flight simmers and trolls. If you
want to open it up to non-pilot lurkers, I'll take a guess. Assuming
you will reveal the correct answer and explain it.
Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently.
Old June 25th 08, 07:32 PM posted to rec.aviation.piloting
glory be, what can the answer be?
for you to explore.
or what?
this hill?
Old June 25th 08, 09:05 PM posted to rec.aviation.piloting
alexy
for you to explore.
or what?
this hill?
My guess is that since the plane will subtend a much smaller angle
than the sun, there would be no noticeable shadow. My guess is a
"halo" around where the shadow would be, caused by diffraction, Since
most of the edges tend to be inline with the plane's axis or
perpendicular to it, it seems that this halo might be somewhat
brighter on those two axes, but I wonder if that would be noticeable.
The halo might have a slightly bluish cast, since the red end of the
spectrum would get diffracted more, and being over a larger area would
be not as bright.
So, what's the real answer?
Old June 25th 08, 10:32 PM posted to rec.aviation.piloting
On Jun 19, 8:49 am, Stealth Pilot
for you to explore.
or what?
Stealth Pilot
Is this a test, or are you curious what the sim does? :/
In real life, you will see a vague outline of the plane,
but it will be pretty fuzzy in general.
In the present sim I use, "FSX" the shadow is always sharp..
They don't have that "fuzzy" technology down yet..
I have pictures of both real shadows, and can easily fire
up the sim for it's version if needed.
Dunno about 4500 ft though.. I'm not sure if he was
quite that high in the best examples I have, which were
taken from a Piper Cub..
The sim has the same Cub, so it would be easy to compare
real to sim, using the same exact aircraft.
But I can tell you right now, the real version is going to be
a lot fuzzier than the sim.
Old June 25th 08, 10:36 PM posted to rec.aviation.piloting
for you to explore.
or what?
Stealth Pilot
look up 'glory' in an aviation context.
Old June 29th 08, 12:53 AM posted to rec.aviation.piloting
Rich Ahrens[_2_]
on 6/25/2008 3:36 PM said the following:
Does it have anything to do with Maxwell in an airport restroom?
Old June 29th 08, 03:09 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
be not as bright.
sitting on the ground with the sun about 93 million miles away the
aircraft casts a sharp shadow on the ground.
at 500ft altitude the aircraft is 500ft closer to the sun than the
previous 93 million miles, which is next to no change at all, so there
will be very little change to the shadow you'd think. but there is. at
500ft the aircraft shadow is a very indistinct blur surrounded by a
halo of bright light.
at 4,500ft (the original question) the aircraft has no shadow at all
but at the sub solar point (were you'd think the shadow should be)
there is a distinct bright area tracking along under the aircraft.
for thirty years this quietly puzzled me. it is a fact that aircraft
at altitude have no shadow. below them tracking along the ground is a
bright spot of light.
the reference I gave gives details of some original work by Fresnel
which proposed that light passing beside a gravitational mass should
be bent slightly by the mass and behind the body there should be a
bright spot. this seems to me to be the explanation for the absense of
the shadow. the mass of the aircraft acts as a gravitational lens and
this causes the bright spot.
the reason I asked the question was to point out that simulators work
on a simplified model of the reality that real pilots are exposed to.
people like mxsmanic seem utterly oblivious to the fact that their
exposure to the simulator will never give them competent knowledge
because all they are exposed to is a simplified model of reality. it
is only exposure to the actual reality that will allow you to achieve
competent knowledge.
if simulators dont get something as simple as the aircraft's shadow
right can you trust that anything else they show you is right?
Stealth Pilot
Pilot's Assistant Directory - Free Information Resource for Flight Simmers - Updated AirToob Simulators 0 July 19th 07 12:10 PM
(OT) MS Simmers Dan544 Piloting 66 May 7th 07 11:04 PM
Slightly O/T for flight simmers. Building my own airport Andrew Scotland Simulators 4 July 24th 05 11:13 PM
Check This Out!!! (must have for all flight simmers) Boeing747 Simulators 1 July 3rd 04 01:43 AM
Calling Simmers in the Midlands, UK 'Mort' Simulators 0 March 24th 04 09:16 PM
