Looking for a Compaq 1550. Thanks, Sam
When you get a 1551, the best thing to do is clean the throttle
position sensor, check its connection, and tighten the ground wire if nearby. Check for other codes, you'll often get a 1565 at the same time. |
On Oct 29, 10:37*pm, Bob Kuykendall wrote:
When you get a 1551, the best thing to do is clean the throttle position sensor, check its connection, and tighten the ground wire if nearby. Check for other codes, you'll often get a 1565 at the same time. I have 2 1530 and a 1550 |
On Oct 30, 11:24*am, Andy wrote:
On Oct 29, 10:37*pm, Bob Kuykendall wrote: When you get a 1551, the best thing to do is clean the throttle position sensor, check its connection, and tighten the ground wire if nearby. Check for other codes, you'll often get a 1565 at the same time. I have 2 1530 and a 1550 I hit the wrong button. Was going to delete the message but now I'll have to complete it to head off the potential purchasers. I was going to say - I have 2 1530 and a 1550,, does that mean I'm grounded? It was a not very funny reply to Bob's reference to OBD II codes. Hence the attempt to delete without sending. Andy |
| Thread Tools | |
| Display Modes | |
