Lockheed Martin KC-130J Given Approval After Intensive Testing ByMarine Corps
Old April 30th 04, 03:27 AM
Henry J Cobb
Default Lockheed Martin KC-130J Given Approval After Intensive Testing ByMarine Corps
http://www.prnewswire.com/cgi-bin/st...2163485&EDATE=
More details about the KC-130J tanker can be found here.
http://www.globalsecurity.org/milita...ft/kc-130j.htm
-HJC
Old May 2nd 04, 06:57 PM
Bob Urz
-HJC
How does "hotel mode" work?
Bob
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old May 2nd 04, 07:11 PM
Yeff
-HJC
Their uniforms turn Air Force blue and their TDY accommodations improve.
-Jeff B.
yeff at erols dot com
Old May 2nd 04, 10:15 PM
Henry J Cobb
http://www.codeonemagazine.com/event..._events33.html
Hotel mode, a unique capability of the C-130J propulsion system that
provides for safer ground loading and unloading operations, was
demonstrated in recent tests at MCAS Cherry Point, North Carolina.
This capability puts the C-130J propellers in feathered position,
which reduces both propeller blast and engine exhaust heat and,
consequently, the amount of dust, dirt, and debris being kicked up
behind the aircraft. The engines remain running in this mode enabling
the pilot to spool them quickly up to military power.
-HJC
Old May 3rd 04, 03:00 AM
Bob Urz
-HJC
I saw what it does already, i was more curious on how.
I have visions of a large clutch pack or such.
That could be a potential failure mode. I am curious
mechanically how they do it.
Bob
Old May 3rd 04, 03:39 AM
Marc Reeve
It also allows them to keep the climate control systems running, which
is commonly called a "hotel load" (lights and A/C). Which is probably
how it came to be called "hotel mode".
-Marc
Marc Reeve
actual email address after removal of 4s & spaces is
c4m4r4a4m4a4n a4t c4r4u4z4i4o d4o4t c4o4m
Old May 3rd 04, 03:43 AM
Steve R.
The LPT is not physically connected to the compressor; only to the prop
gearbox. The pitch control unit routes oil through the Beta tube to the prop
to set it to feather. Since the LPT isn't connected to the HPT or the
compressor, it can turn at a much slower speed. That is the reason the
engine spools up faster than the T-56 also. If you're doing a man on the
stand you apply a bit of reverse pitch because in hotel mode you still have
some prop blast.
Steve R.
"Bob Urz" wrote in message
-HJC
Bob
Old May 6th 04, 03:11 AM
-HJC
Bob
Hell yes!!...how indeed?, that's a very interesting
development...I'm assuming that this isn't the normal Allison
C-130 engine?
-Gord.
Old May 6th 04, 03:29 AM
some prop blast.
Steve R.
Ok, so it's 'not' a T-56 then...do you know what it is?...and
what RPM does the prop turn at in that mode?...most
interesting...
-Gord.
Old May 6th 04, 04:49 AM
Steve R.
"Gord Beaman" wrote in message
prop
have
some prop blast.
Steve R.
interesting...
-Gord.
(Note: I get this whole top post/bottom post thing messed up, so forgive me
if I switch back & forth. )
The J-model has the Rolls Royce AE2100D-3 engines. The AE2100 engine is used
in the Saab 2000, C-27J and in the AE1107 configuration in the V-22 Osprey.
I do not know the prop RPM in HOTEL mode, but it is approx. 25-30% Np RPM,
where low speed ground idle is 71-73% Np RPM.
Steve R.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
Lockheed Martin completes first F-16I for Israel Henry J. Cobb Military Aviation 16 November 19th 03 02:22 PM
Shooting at Lockheed Martin plant. Gil G. Military Aviation 14 August 14th 03 09:59 AM
6 reported slain at Lockheed Martin facility in Mississippi Bertie the Bunyip Military Aviation 60 July 15th 03 11:23 AM
Shooting at a Lockheed Martin plant Quant Military Aviation 0 July 8th 03 06:02 PM
