When to buy an engine.
Old October 12th 03, 12:08 AM
Ebby
Default When to buy an engine.
Calling on the group for advice. I have stumbled upon an O-320 off a C-172.
The engine has 2780 since new and is timed out. Although when ferried from
the south, on a 9 hour flight it only used 1 qt. I get the mags, engine,
logs and new carb for $4000. Is that good? No storage. It came right off
the C-172. I am only at the stage of welding up my fuselage but wanted to
know if this is a good deal and is it too early to buy my engine?
Ebby
Camden, NY
Old October 12th 03, 12:34 AM
Rich S.
"Ebby" wrote in message
C-172.
from
off
O-320-??????
Makes a big difference.
Rich S.
Old October 12th 03, 02:58 AM
Barnyard BOb --
C-172.
from
off
O-320-??????
Rich S.
My take is.......
The 0-320 - H2AD is normally avoided
unless it has had the cam and lifter mods.
The 0 -320 - E2D is good.
If your application requires a fuel pump,
you will need an accessory case from
something like a Piper Cherokee. The
Cessna 172 acc case has no mechanical
fuel pump capability unless you have it
machined for such.
An 0 -320 - E2D core as you describe
can command $4000. If it was me...
I would fly behind it until I had my first
flight and some time built on the new
plane.
New airframe, new overhaul and new
pilot can present a first flight situation
that introduces more unknowns than
one might want to chance all at once.
You can pickle the engine until you're
ready for it.... or pass it up in hopes for
a better deal.
Barnyard BOb -- over 50 years of flight
Old October 15th 03, 12:46 AM
Ebby
Here is a follow-up to my original post. I went back to visit the engine
and pour over the log books. The engine is an O-320-E2D. It has 2750 hours
total time. It has had one major overhaul. All AD's have been complied
with and the crankshaft has been machined .003" with no pitting found
inside. The records were meticulous as the engine came out of a Part 141
flight school. The engine was never stored. In fact the owner swapped a
fresh rebuild right after flying the plane from Florida. In 9.5 hours oil
consumption was 1 qt and the gauges were in the green all the way up from
Fla. The starter is less than a year old and the carb is less than 1000
hours old. Compressions at the last 100 hour were mid 70's. Never had any
oil contamination. The only thing bad I can find about the engine is it is
past TBO. Anything else I should consider before plunking down the cash?
Ebby
Hatz s/n 598
Old October 15th 03, 01:34 AM
Jerry Springer
If it has 2750 total time, why was it overhauled early the first time?
If it is now past TBO that means it was overhaouled early the first
time. The O-320-E2D should run to TBO with no problem which is 2000
hours. Still sounds like a good price for this engine
Jerry
Ebby
Hatz s/n 598
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
