1946 stinson ( Radio Buss Relay Install )
Old May 19th 09, 11:06 PM posted to rec.aviation.piloting
goldaussy
Default 1946 stinson ( Radio Buss Relay Install )
Hello:
I am working on a 46 stinson and have a
question as I am wiring it from scratch,
I accessed the battery box which is in the aft section of the
airplane
and found the master relay mounted on the side of the battery box ,
as
stated in AC43 the relay should be within 2 feet from the battery,
this seems to be right, The question is since I am installing a
Radio
Master switch , should the relay be intalled in the same place with
the master relay and run another battery cable forward or could it go
on the firewall and have the master relay supply power to the radio
master relay.
Thank you for any help.
Old May 20th 09, 07:49 PM posted to rec.aviation.piloting
Flaps_50!
On May 20, 9:06*am, goldaussy wrote:
Hello:
airplane
as
this seems to be right, *The question is since I am installing a
Radio
master relay.
One thought -would you have separate cables to the battery for the
charger?
Cheers
Stinson Voyager 108-1 - 1946 goldaussy Piloting 0 May 6th 09 07:05 AM
Air buss loss at Paris Airshow? Danny Dot Piloting 78 December 21st 06 09:32 AM
Master Buss Bar? ccwillwerth Home Built 18 January 20th 06 03:32 AM
Relay David Home Built 5 July 20th 04 05:11 PM
Electrical Relay Help Jeff Home Built 10 August 29th 03 05:03 AM
