Can anyone verify this story about Blackbirds?
Old June 30th 04, 04:14 PM
Jaeger
Default Can anyone verify this story about Blackbirds?
I remember reading about SR-71(Blackbird) aircraft flying in Swedish
airspace on recon missions to Russia, chased by the Swedish air force.
Apparently the Swedish aircraft never got into air even before the
Blackbird had exited Swedish airspace. The Blackbird pilots even sent
the Swedes Christmas post cards with compliments about their attempts
to get them.
Anyone else know of this story? Is it true?
Old June 30th 04, 06:13 PM
Jukka O. Kauppinen
I suspect the SR-71s have flown intentionally in Swedish airspace. The
Blackbirds did however run a regular route in the international
airspace, at times very close to the Swedish border.
Swedes did intercept SR-71, though. With careful calculated interception
a Swedish fighter did streak into intercept position and got a radar
lock. The SR-71 flights over the Baltic Sea and Gulf of Finland stopped
for several weeks after that with the USAAF trying to find out how the
Swedes could do that.
The story below seems just a fabrication - how the Blackbird pilots or
anyone could even know that the Swedes tried to get them, if they didn't
even get planes up before they'd exited?
Another variation of this story tells, that the Blackbird pilots sent
the Swedes a trophy for being the only people ever to have intercepted
an SR-71. Given the circumstances that is far more believable, since an
interception is known to have happened.
jok
to get them.
Old June 30th 04, 11:05 PM
Kevin Brooks
"Jukka O. Kauppinen" wrote in
message ...
First, with an absolute maximum ceiling of about 65K feet, how could a
Draken have acheived a radar lock on a SR-71 flying at its operational
altitude (the ol' "in excess of 85K feet" bit)? Second, the USAAF would have
been hard pressed to investigate a situation that came along twenty-five or
more years after it ceased to exist..:-)
Cite?
Brooks
jok
to get them.
Old June 30th 04, 11:37 PM
Harry Andreas
In article , "Kevin Brooks"
message ...
An altitude difference of 20 000 ft is less than 4 miles.
If the SR was cruising at 100 000 ft that's still only 6.6 miles.
Any radar has more range than that, even looking up.
Harry Andreas
Engineering raconteur
Old June 30th 04, 11:53 PM
Kevin Brooks
"Harry Andreas" wrote in message
message ...
interception
stopped
OK, I should have rephrased--how could the Draken have posed an actual
threat to the SR? And, I'd be mightily surprised if said Draken was actually
operating at its tippy-top ceiling capability...
Brooks
Harry Andreas
Old July 1st 04, 12:21 AM
Kyle Boatright
"Kevin Brooks" wrote in message
in
message ...
The
interception
stopped
actually
Brooks
I would think a head on-shot after a pop-up intercept would have a
meaningful Pk if the intercept was run perfectly. The problem is getting to
the right point in time and space to take the head-on shot.
KB
Old July 1st 04, 04:13 AM
noname
Brooks
It was a Viggen.
Old July 1st 04, 05:25 AM
Kevin Brooks
"Kyle Boatright" wrote in message
wrote
in
message ...
The
interception
radar
stopped
a
operational
actually
Brooks
to
I'd think head-on the SR would likely present a pretty small RCS (it was
after all known for being rather stealthy for its day)--couple that with its
speed, the interceptor's speed (i.e., one heck of a closure velocity), and
the idea that the Draken would have to be lugging at best a couple of Rb
27/28 (read as "Falcon") AAM's, and I don't see it as very doable. Color me
dubious.
Brooks
KB
Old July 1st 04, 01:24 PM
Smartace11
to
dubious.
Brooks
I am not sure about their real stealthiness, at least from the rear hemisphere.
Yeah I know the chances of a shot from that quarter are not the best to say
the least.
Went on a F-4E Functional Check Flight out of Korat once. The FCF involves
among other things, doing a Mach run around 2.0 somewhere between FL400 and
FL500. On this particular flight I found and locked on to a very high speed
tartget target well above us with a huge negative closing range. We were M2+
and probably at FL450 over nothern Thailand headed NE. Stayed locked on long
enough to have been able to get an AIM 7 off though I suspect the PK wasn't the
greatest. The Mach run was interrupted by a #1 engine compressor stall so we
had other things to do besides play with that bogey.
On another occaision we were #2 for the active behind a Blackbird at Kadena.
After he took off and we took the active I locked on to him and again stayed
locked on until he was about 15 miles out.
Both were in friendly airspace so I suspect that whaterver ECM those bogeys had
was turned off, as well. The F-4 radar was very susceptible to gate stealers.
Old July 1st 04, 05:31 PM
Typhoon502
"Kevin Brooks" wrote in message ...
dubious.
Points for close enough? Hey, no reason for the Habu drivers to not
have a sense of humour about it.
FS: 1990 "Hornet: The Inside Story of the F/A-18" Fighter Jet Book Jim Sinclair Aviation Marketplace 1 November 8th 05 10:06 AM
Iran Says 'Complete Story' Given to Inspectors Dav1936531 Military Aviation 0 April 25th 04 01:42 PM
FS: 1990 "Hornet: The Inside Story of the F/A-18" Fighter Jet Book J.R. Sinclair Aviation Marketplace 0 December 4th 03 06:38 AM
FS: 1990 "Hornet: The Inside Story of the F/A-18" Fighter Jet Book Jim Sinclair Aviation Marketplace 0 September 15th 03 05:56 AM
PFC Lynch gets a Bronze Star? Brian Military Aviation 77 August 2nd 03 12:15 PM
