NTSB releases probable cause for Steve Fossett crash
Old July 10th 09, 12:44 AM posted to rec.aviation.piloting
Jim Logajan
Default NTSB releases probable cause for Steve Fossett crash
http://www.ntsb.gov/ntsb/brief.asp?e...07X17184&key=1
Old July 10th 09, 02:47 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Jim Logajan" wrote in message
Thanks for the link
Geoff
Old July 10th 09, 03:14 AM posted to rec.aviation.piloting
Jim Logajan
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote:
Thanks for the link
I almost made the mistake of linking to one of the news stories.
Old July 10th 09, 04:14 AM posted to rec.aviation.piloting
Mike Ash
Thanks for that. Ultimately nothing too surprising. Turbulence exceeded
his plane's performance, and he ran out of airspeed, altitude, and ideas
before it let up. Certainly, turbulence can be violent in that area when
the winds are as described.
Still, good to know, and good to think about. If it can happen to him,
it could happen to you!
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old July 10th 09, 02:30 PM posted to rec.aviation.piloting
Gezellig
How long after first impact should it take for the ELT to kick out a
call on frequency?
Old July 10th 09, 03:01 PM posted to rec.aviation.piloting
Mike Ash
call on frequency?
I assume pretty quickly, but if you're referring to the Fossett crash,
note that the NTSB report says the ELT was destroyed on impact.
Mike Ash
Radio Free Earth
Old July 10th 09, 03:30 PM posted to rec.aviation.piloting
Gezellig
call on frequency?
I didn't catch the "on impact" only that it was destroyed. I guess they
judged that no signal meant destroyed on strike, must have been a hell
of a crash reading through the report.
I'm looking at the pictures, wow, not pretty. Do all the S Decathlons
have clear canopies?
Old July 10th 09, 03:40 PM posted to rec.aviation.piloting
Mike Ash
call on frequency?
Oops, you're right, I must have subconsciously assumed the "on impact".
Seems probable that the impact is what destroyed it, but it doesn't say
that, and it certainly could have happened later (e.g. in the fire). My
apologies.
Mike Ash
Radio Free Earth
Old July 10th 09, 03:48 PM posted to rec.aviation.piloting
Gezellig
call on frequency?
apologies.
That's what led to my question. I've never had the "opportunity" to set
off an ELT but I thought they were required to have a gyro or gravity or
some kind of ability to detect crash instantaneously and play out to
406.
CAP was combing the area by the NTSB with no report of transmission so I
suppose we can extrapolate that a severe enough impact can render the
ELT useless. I am guessing where the AC took the initial hit would be
important too in relation ot the positioning of the ELT in the AC.
Old July 10th 09, 04:35 PM posted to rec.aviation.piloting
vaughn[_2_]
"Mike Ash" wrote in message
apologies.
If it were the fire, then the ELT would be history within 2 or three minutes
of the crash. It would be long-gone hours before anyone was listening for
it.
Depending on the type of installation, another possibility is that an ELT
can simply get separated from its external antenna. That would greatly
reduce its range (from a matter of miles to a matter of feet). From the
choice of words "destroyed" that was apparently not the case in this crash.
Vaughn
Steve Fossett Steve Piloting 32 December 8th 08 03:19 PM
Steve Fossett bumper Soaring 10 December 5th 08 08:11 AM
Steve Fossett NoneYa Piloting 32 September 11th 07 03:45 AM
Steve Fossett Brian Milner Soaring 3 September 8th 07 09:26 AM
Steve Fossett [email protected] Owning 15 September 7th 07 09:45 PM
