All sailplane owners,
Please reply with the weight on your tail wheel from your weight and balance sheet. I will calculate the average after a few days and post it and the range. Reply on this list or directly to me, either way is fine. Thanks. |
Ventus C (all up)
Nose wheel: 772 lbs tail wheel 36.3 lbs C/G 4.5" aft of datum (76% aft) |
On Wednesday, December 5, 2012 11:49:48 AM UTC-6, soartech wrote:
All sailplane owners, Please reply with the weight on your tail wheel from your weight and balance sheet. I will calculate the average after a few days and post it and the range. Reply on this list or directly to me, either way is fine. Thanks. It would be nice to know what you try to accomplish. Also there are so many variables going into the tail wheel weight. A Genesis probably will be much different from a Duo Discus. You should also specify if this weight is for the empty glider or with the pilot and chute. |
Looking from a medical viewpoint?
Going by just tail weight, perhaps Martin Heide has friends who are chiropractors. Jim On Wednesday, December 5, 2012 10:43:36 AM UTC-8, wrote: It would be nice to know what you try to accomplish. |
Empty:
Std Cirrus - 65 lbs on tail Cherokee II - ~25 lbs on tail NG-1 - ~5 lbs on tail |
On Wednesday, December 5, 2012 11:55:17 AM UTC-7, JS wrote:
Going by just tail weight, perhaps Martin Heide has friends who are chiropractors. I suspect Martin just inherited this design feature. My 28 runs about 60lb on the tail, ballasted and with me in the cockpit. I have to lift a lot more than that to put the tail dolly on. I have no record of the tail weight for that condition but it calculates to approx 90lb. Attempting to answer the OP's question - In specified weighing attitude, no ballast and no pilot, tail 67lb. Same with pilot and chute in cockpit, tail 37.5lb. As others have pointed out, the conditions for measuring tail weight have a huge influence on the result. No data will be of any value unless the conditions are specified. Andy (GY) |
On Dec 6, 6:19*am, Andy wrote:
On Wednesday, December 5, 2012 11:55:17 AM UTC-7, JS wrote: Going by just tail weight, perhaps Martin Heide has friends who are chiropractors. I suspect Martin just inherited this design feature. *My 28 runs about 60lb on the tail, ballasted and with me in the cockpit. *I have to lift a lot more than that to put the tail dolly on. *I have no record of the tail weight for that condition but it calculates to approx 90lb. Attempting to answer the OP's question *- In specified weighing attitude, no ballast and no pilot, *tail 67lb. *Same with pilot and chute in cockpit, tail 37.5lb. As others have pointed out, the conditions for measuring tail weight have a huge influence on the result. *No data will be of any value unless the conditions are specified. Andy (GY) Janus C - 64 lbs Speed Astir II - 90 lbs |
ASW-19B = 70 lbs
LS8-18 = 67 lbs Both values without pilot or chute, and both done using manufacturer's specified tail position. -John |
On Wednesday, December 5, 2012 10:49:48 AM UTC-7, soartech wrote:
All sailplane owners, Please reply with the weight on your tail wheel from your weight and balance sheet. I will calculate the average after a few days and post it and the range. Reply on this list or directly to me, either way is fine. Thanks. LAK12 empty 34.5kg 76lbs |
Kestrel 19
104 lbs on the tailwheel, empty Can you say, "Oh, my aching back!"? ![]() |
ASK-21 Weight and Balance | Carl Baxter | Soaring | 4 | June 2nd 11 02:57 PM |
PA-32 Weight and Balance | John Doe | Owning | 14 | May 23rd 06 01:03 AM |
L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 01:54 AM |
Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 05:11 PM |
Weight and Balance | JP | Piloting | 2 | January 13th 04 10:54 AM |
