PW-5 Brake Cable Replacement
Old July 31st 14, 03:44 PM posted to rec.aviation.soaring
Default PW-5 Brake Cable Replacement
To All,
The brake on our PW-5 has failed. The brake cable end that attaches to the hand brake handle came loose from the handle.
The cable was attached to a pin that fits into the brake handle. The steel pin is retained in the brake handle by a snap ring. The pin was evidently soldered or welded onto the steel cable.
Has anyone experienced such a failure? If so, how did you go about replacing and installing the cable?
We have purchased a replacement cable from Poland but it arrived with only a single swagged ball at one end. Trying to weld or solder the existing pin onto the new cable seems to be a very risky proposition.
Any help will be greatly appreciated.
Charley
Old July 31st 14, 07:41 PM posted to rec.aviation.soaring
Tim Taylor
On Thursday, July 31, 2014 8:44:24 AM UTC-6, wrote:
To All,
Charley
Likely to be some form of a motorcycle brake or clutch cable. Best to find an old fashion motorcycle shop and see if they can find or make a cable for you. The newer shops only know how to look up part number so are not much help.
G102 Club III Brake replacement Hartley Falbaum Soaring 1 June 7th 12 07:36 PM
Blanik L-13 elevator cable replacement Brad[_5_] Soaring 7 April 24th 10 06:56 PM
Pilatus B-4 Wheel Brake Cable thermalrider Soaring 2 January 28th 06 11:12 PM
Prop Cable - Replacement Needed zatatime Owning 0 May 7th 04 04:37 PM
Nimbus 3 25.5 tip spoiler cable replacement tango4 Soaring 0 May 3rd 04 09:05 PM
