weight and balance question
Old June 28th 16, 02:30 AM posted to rec.aviation.soaring
Duster
Default weight and balance question
Our club needs to do a weight and balance on our Grob 103 after refinishing and some other mods. We are wanting to use calibrated/certified scales, but the cost of having it weighed or purchasing a set of scales is quite high.. What have others done to get their W&B completed yet not break the bank? We are in the San Antonio area.
From reading FAA circular 8083-1a and Part 91, it isn't even clear that we are required to use certified scales (not that we wouldn't want to). W&B apparently can even be calculated mathematically w/o weighing the aircraft and not every production e.g., Cessna 172s, need be weighed at all (they can weigh 10-20% of the run).
Old June 28th 16, 03:30 AM posted to rec.aviation.soaring
Bill T
Find a local car club, they may have 4 electronic scales or know someone who does. A good local airplane shop may have portable electronic scales or know someone who does. Remeber, the key is to correctly level the glider on the scales to get main and tail weight, inside a hanger with all the cooling fans off.
BillT
Old June 28th 16, 09:03 PM posted to rec.aviation.soaring
Good idea..... Also check your local aircraft mechanic, good automotive shop (preferably one that does race suspensions/"corner weighting"), etc.
Another option is do a local "consortium" of airports/glider clubs on buying your own scales.
Old June 28th 16, 03:57 PM posted to rec.aviation.soaring
WB
On Monday, June 27, 2016 at 8:30:22 PM UTC-5, Duster wrote:
Our club needs to do a weight and balance on our Grob 103 after refinishing and some other mods. We are wanting to use calibrated/certified scales, but the cost of having it weighed or purchasing a set of scales is quite high. What have others done to get their W&B completed yet not break the bank? We are in the San Antonio area.
I bought a 660 lb floor scale off Ebay for $50 plus shipping to W&B on my own glider. That's too small for your Grob, but there are higher capacity scales on Ebay or you can double up with two of the 660 lbs scales. Just a quick look on Ebay yielded a 5000lb digital floor scale for $499.
Old June 28th 16, 06:49 PM posted to rec.aviation.soaring
Benedict Smith
refinishi=
scales,
hi=
bank=
=20
w=
W&B
aircraft
ca=
o=
sc=
qu=
A cheaper solution would be to find your nearest public weighbridge (not
sure
if they are called something else in the US) and get the trailer weighed
empty
and again with the glider in it, simply subtracting the trailer weight
would
give you the glider weight, as these weighbridges are for commercial use
they should be calibrated and would give you an accurate figure.
Old June 28th 16, 08:53 PM posted to rec.aviation.soaring
refinishi=
scales,
hi=
bank=
=20
w=
W&B
aircraft
ca=
o=
sc=
qu=
sure
empty
would
It's not so much a question of empty weight, but where the CG is located, So weighing the glider in a trailer is useless.
Old June 29th 16, 03:57 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Ah, but if you know the total weight of the glider, you can then use a calibrated (or verified) bathroom type scale under the wheel that has the low weight on it, and from that determine the weight on the "heavy" wheel, measure moment arms (or trust factory measurements) and calculate C of G location.
So, I respectfully disagree with your conclusion that weighing the glider in the trailer is "useless". It is just the first step to determining empty weight and C of G.
You could also weigh each part separately, sum them to get total weight, then get the weight on the light wheel with the plane assembled and properly leveled, and calculate C of G location.
But, I agree it is far easier to get an appropriate set of scales, and weigh the assembled airplane!
Steve Leonard
Old June 29th 16, 04:06 PM posted to rec.aviation.soaring
Steve Leonard
Further to Steve's point.
A quick and dirty safety check is to level the glider and weigh the tail with an accurate scale.
Comparing the tail weight to what is shown on the last measured weight and balance will show whether there is something to be concerned about from a safety point of view.
This can be done with the bathroom scale we all have.
It is not a substitute for the real thing but it will show if you have a likely problem.
I did this when my first '20 was really hairy to fly after I bought it. This disclosed the 13 pounds of undocumented tail weight.
UH
Old June 28th 16, 08:50 PM posted to rec.aviation.soaring
Papa3[_2_]
FWIW having just completed a W&B for a Grob recently. I'd be more concerned about making sure you have all of the geometry measurements correct including (especially) leveling the glider per the W&B instructions in the manual. A couple CM of error in a dimension (e.g. datum to the tail weighing location) has a lot more impact than 1 lb error in the scale itself. If you have concerns about the scale, it's pretty easy to do some simple calibrations/tests yourself. A plastic 55 gallon drum filled to the reference mark with water (for example) gives you a pretty good indication. Don't forget to adjust for temperature in the specific weight of water.
Old June 28th 16, 08:57 PM posted to rec.aviation.soaring
Keith M
We have been able to rent a suitable scale here in Houston. San Antonio has some rental places according to Google.
Weight/balance question Bob Martin Home Built 9 June 18th 04 09:01 PM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Simple weight/balance question Frode Berg Owning 16 March 2nd 04 01:39 PM
Weight & Balance Question Harry Gordon Piloting 28 December 30th 03 01:51 AM
Weight and balance question. Wayne Piloting 5 November 28th 03 06:45 PM
