Hi Stewart,
The Ventus CM introduced in 1989 used a carbon fuselage with a carbon / kevlar fabric in the bottom of the seat area only. The carbon fuselage was to save weight for the motorglider, but the kevlar was for crash protection. The kevlar / carbon layer is visible on the inside, so I assume it is the last layer in the layup. This would make it feasible to add a layer to your glider. The newer cockpits are much stronger with rails below the canopy and stiffer layups. The curved canopy of the ASW 24, 26, 27, 28 is an important part of a safety cockpit because it reduces the weak point that the other sailplanes have at the sharp corners of the canopy frame. Much testing has gone into the new fuselage designs. The new LS10 uses a curved canopy frame as well. Rick Walters |
The Pegase 101 CC (a carbon spar version of the 101A) manufactured in
1983, used kevlar extensively in the cockpit area. I don't know whether Marc Ranjon did this for crashworthiness, though it wouldn't surprise me. Marc was putting winglets on ASW-20s and Pegases in 1981. Forward thinker. Most of his contemporaries required 10+ years of convincing. |
| IS-28 Fuselage Construction | smjmitchell | Soaring | 5 | December 31st 03 03:07 AM |
| LS4 - LS6 Fuselage size | Mark | Soaring | 15 | November 3rd 03 04:47 AM |
| #1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 04:04 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
| Fitting canopy frame to fuselage advice | Deputy Dog | Soaring | 5 | July 27th 03 05:08 AM |
