Paint for white fiberglass trailer top
Old June 21st 20, 04:00 PM posted to rec.aviation.soaring
Senna Van den Bosch
Default Paint for white fiberglass trailer top
I got an older Anschau Komet trailer that needs some care and decided to repaint the entire top side, which is white painted fiberglass. What paint would you recommend for doing this? I'd like it to be a bit glossy and waterproof, as the trailer will stay outside in summer but hangared in winter. Thanks!
Old June 21st 20, 08:22 PM posted to rec.aviation.soaring
WB
I repainted one fiberglass trailer with Benjamin Moore gloss exterior latex house paint. Sprayed it with an HVLP sprayer. Looks fine, but has a little more "orange peel" texture than I would like due to not thinning the paint enough. Should have rolled it on. Note that it will blister if you trap moisture against it (like putting a tarp over it). Otherwise, it seems to be holding up very well.
Any of a number of quality "topside" boat paints are suitable. There are single part topside paints that are designed to be rolled on (or may be sprayed on). The advantage to roll on application is that you won't need expensive safety equipment and expensive spraying equipment. The single part paints have a big downside in that they don't sand out well like a two part paint. There are also good two part polyurethane topside boat paints that are designed for roll on application. They can be sanded smooth to take out any roller or brush marks. Jamestown Distributors is one popular vendor of many brands of boat paints and supplies. https://www.jamestowndistributors.co...portal/main.do
Old June 21st 20, 08:25 PM posted to rec.aviation.soaring
WB
I got an older Anschau Komet trailer that needs some care and decided to repaint the entire top side, which is white painted fiberglass. What paint would you recommend for doing this? I'd like it to be a bit glossy and waterproof, as the trailer will stay outside in summer but hangared in winter.. Thanks!
Probably the best compromise of cost/quality is to sand/repair as necessary and then take it to an automotive paint shop and let them spray a polyurethane based paint. Seen that done a few times on glider trailers with excellent results.
Old June 22nd 20, 05:49 PM posted to rec.aviation.soaring
Tony[_5_]
On my Komet I did a light sanding with a disc sander and then rolled on white house paint from Ace Hardware. It was a combo primer/paint, cant remember the brand. Still looks good a couple years later. I figured houses sit out in the sun all the time and the paint holds up pretty well
Old June 22nd 20, 06:42 PM posted to rec.aviation.soaring
David Laitinen
We have used reflective roof coatings such as Kool Seal. Seals up any
minor leaks and also reduces the temperature inside the trailer.
Old June 23rd 20, 12:36 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
I refinished a Komet trailer 3 yrs ago with Boat paint . Self leveled and didn't see any roller marks afterwards. Came out great, UV protection as well although about $50.00 a Qt. I sanded first with an orbital sander 150 and used 5 coats .
Very good coverage for a qt.
Also afterwards I used a white roofing silicone along the galvanized base .
https://www.jamestowndistributors.co...ide+Boat+Paint
Old June 23rd 20, 01:15 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
That seems to be a good way to go. I'm talking to one of the painters at my work and he has offered to help with my glider and trailers. The company allows and encourages 'homers'
We have a 70m long paint booth at work which is used for the CF masts and booms that we produce.
:-) Colin
Old June 22nd 20, 07:48 PM posted to rec.aviation.soaring
Senna Van den Bosch
Op zondag 21 juni 2020 21:25:35 UTC+2 schreef WB:
Well I was thinking this, but I would like to paint it myself, roller if possible, as it is much more cost effective and I don't like to outsource what I could potentially do myself
Old June 23rd 20, 12:49 AM posted to rec.aviation.soaring
Cookie
I used this stuff from Jamestown distributors...one part polyurethane.
http://www.totalboat.com/product/wet... AEgKBqfD_BwE
Use their primer first...you can sand, and prime, sand and prime, lightly sand until really smooth. then the top coat...look for their videos on the "roller and tip" method....won't be like an automotive pro spray job...but you can make a trailer look really nice...
Cookie
Old June 21st 20, 09:22 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Several at my club have used this: https://www.thechandleryonline.com/p...roducts_id=582 to refinish their trailers. I am doing mine this fall with the same product. Five year-old refinish jobs look amazing, and it is not hard to do.
I imagine a sailing supply shop will have this, or similar, in Europe.
Cobra trailer aluminum vs fiberglass top 2G Soaring 31 July 20th 18 03:32 AM
Foam for inside of fiberglass trailer John[_27_] Soaring 9 April 4th 13 04:12 AM
Painting fiberglass Cobra trailer [email protected] Soaring 12 January 19th 13 02:23 AM
Touch Up White Paint O. Sami Saydjari Owning 10 May 29th 05 11:58 PM
Painting a Fiberglass Trailer Experiences ContestID67 Soaring 4 April 28th 05 07:40 PM
