I'm working on a little aluminum airplane that has some surface
corrosion just under the paint in a couple places. What do you guys use as a treatment to stop the aluminum corrosion? I remember 30 years ago using phsophoric acid then a zinc chromate converstion treatment. Is this still the best technique to stop the corrosion? I need to just abate the current corrosion from expanding. What do you guys recommend? BWB |
Etch and alodine is still the best way.
Use a 3-M 7447 Scotch Brite pad to help remove the corrosion. A good epoxy primer followed by topcoat and you should have the problem solved. |
On 1 May 2005 08:55:26 -0700, "Clay"
wrote: Etch and alodine is still the best way. Use a 3-M 7447 Scotch Brite pad to help remove the corrosion. A good epoxy primer followed by topcoat and you should have the problem solved. THanks |
Corrosion Proofing | Clay | Owning | 7 | April 22nd 05 12:03 AM |
painted airtight window screen as a "surface" | Allan Morrison | Home Built | 3 | February 19th 05 03:40 AM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
How much corrosion is too much? | Carl Orton | Owning | 5 | February 2nd 04 01:31 AM |
Corrosion X Applicators | Hankal | Owning | 5 | July 7th 03 06:07 PM |
