Tonight I'm going to install a prop on my plane (Pietenpol with a Continental A-75) and go up for a quick flight. I've never done a prop install before, so I want to make sure I get it right.
I figured I'll torque the bolts, run the plane for 10-15 minutes on the ground, check the torque, take it up for a brief test flight, then check the torque again. Any tips or things I should be careful for or watch for? I'm a little nervous as I'll be doing it without anyone looking over my shoulder. |
![]() "SteveR" wrote in message ... Tonight I'm going to install a prop on my plane (Pietenpol with a Continental A-75) and go up for a quick flight. I've never done a prop install before, so I want to make sure I get it right. I figured I'll torque the bolts, run the plane for 10-15 minutes on the ground, check the torque, take it up for a brief test flight, then check the torque again. Any tips or things I should be careful for or watch for? I'm a little nervous as I'll be doing it without anyone looking over my shoulder. -- SteveR If the prop flys off land immediately. Other than that it sounds like a plan. |
In article XE9De.40420$DC2.33578@okepread01,
Gig 601XL Builder wr.giacona@coxDOTnet wrote: "SteveR" wrote in message ... Tonight I'm going to install a prop on my plane (Pietenpol with a Continental A-75) and go up for a quick flight. I've never done a prop install before, so I want to make sure I get it right. I figured I'll torque the bolts, run the plane for 10-15 minutes on the ground, check the torque, take it up for a brief test flight, then check the torque again. Any tips or things I should be careful for or watch for? I'm a little nervous as I'll be doing it without anyone looking over my shoulder. -- SteveR If the prop flys off land immediately. If the prop flys off -- make sure that the rest of the plane stays in formation with it! *grin* |
SteveR wrote:
Tonight I'm going to install a prop on my plane (Pietenpol with a Continental A-75) and go up for a quick flight. I've never done a prop install before, so I want to make sure I get it right. I figured I'll torque the bolts, run the plane for 10-15 minutes on the ground, check the torque, take it up for a brief test flight, then check the torque again. Any tips or things I should be careful for or watch for? I'm a little nervous as I'll be doing it without anyone looking over my shoulder. Don't forget the front plate. Make sure the prop bolts aren't bottoming out on the threads. Don't confuse in-lb with ft-lb(yikes!). 10-15 minutes running on the ground seems unnecessarily long. Just run up briefly on the ground and recheck torque, then blast off. ![]() David - email: David at AirplaneZone dot com |
"David Odum" MyFirstName@AirplaneZone wrote in message
... Tonight I'm going to install a prop on my plane (Pietenpol with a Continental A-75) and go up for a quick flight. I've never done a prop install before, so I want to make sure I get it right. Don't forget to track the prop to make sure the blades run in the same plane within the limits established by the prop maker (usually 1/16" - 1/8" or so). Rich S. |
On Tue, 19 Jul 2005 09:54:02 -0700, "Rich S."
wrote: Don't forget to track the prop to make sure the blades run in the same plane within the limits established by the prop maker (usually 1/16" - 1/8" or so). Rich S. Rich, if it isn't, how do you fix that? I've heard this a lot and it makes sense that you want the prop tracking properly, but how do you do it? Corky Scott |
On Wed, 20 Jul 2005 09:05:52 -0400, Corky Scott
wrote: Rich, if it isn't, how do you fix that? I've heard this a lot and it makes sense that you want the prop tracking properly, but how do you do it? Nevermind Rich, jls answered the question. Corky Scott |
"Corky Scott" wrote in message
... On Wed, 20 Jul 2005 09:05:52 -0400, Corky Scott wrote: Rich, if it isn't, how do you fix that? I've heard this a lot and it makes sense that you want the prop tracking properly, but how do you do it? Nevermind Rich, jls answered the question. Corky........ I've been able to adjust the track on my prop about 1/16" by varying the torque on the bolts slightly (but still within upper & lower limits). It is now within 1/16" of perfect - close enough for me. If it was 1/8" and wouldn't straighten out further, I'd send it back to the maker; assuming my prop flange was dialed in. Speaking of that, I guess if a prop flange was off a few thousandths, you could set up the prop on the flange so the errors would tend to cancel out. Rich S. |
![]() "Corky Scott" wrote in message ... On Wed, 20 Jul 2005 09:05:52 -0400, Corky Scott wrote: Rich, if it isn't, how do you fix that? I've heard this a lot and it makes sense that you want the prop tracking properly, but how do you do it? Nevermind Rich, jls answered the question. Corky Scott To find the prop's track, I stand a stool or small ladder as close to the tip as possible, first fore, then aft of the prop's circumference. You pull the prop through with all wheels tightly chocked and the top plugs removed. When the prop is tracked properly, both tips will track the same cat's hair -- in the direction of the longitudinal axis of the aircraft-- from the edge of the stool, or whatever makeshift pointer you may erect for the purpose, like for example a screwdriver tip or ice pick c-clamped to a small stepladder. You can also find if the prop blades are same length too.* Do it in the hangar, not outside in the wind. Sometimes a crankshaft flange out of limits will throw you when the prop may be OK. I've seen it and done a lot of head-scratching until we did a runout on the steel flange. There are prop-struck flanges out there with big double-digit runouts on them, which of course you find with a good dial indicator. 36 or so inches out to the tip and that flange slop is magnified. *We had an aircraft which had a pre-buy done, and the owner was upset to hear his aluminum blades were unequal by a quarter inch. We set up a pointer and showed him they were in fact dead nuts equal. Measuring helps too, of course. Pointers or dial indicators are also great for meticulous installation of a spinner. There's nothing more obnoxious than a spinner wobbling like hell while the engine idles. Yesterday at KFQD I saw the world's most beautiful 1946 Globe Swift. That thing was a joy to behold and when the 6-cylinder IO-360 Continental engine sprang into motion, the polished aluminum spinner tracked to the naked eye like it had been put on using a dial indicator. It is said you can buy that aircraft for something in excess of 100k. See Van Van der Ploeg in Greenville, SC. |
Make sure you back of the bolts before you re-torque them.
HUB COMPRESSION METHOD Hub Thickness (in.) Desired Hub Compression Bolts Torque (Bolt Rev.) 3 3/8 0.020 3/8-24 0.49 1/2-20 0.41 4 0.024 3/8-24 0.58 1/2-20 0.48 4 3/4 0.029 3/8-24 0.68 1/2-20 0.57 5 3/8 0.032 3/8-24 0.77 1/2-20 0.65 CAUTION: Final bolt-torque should be within the range shown below, Table No. 2 TABLE NO. 2 WOOD PROPELLER INSTALLATION TORQUE WRENCH METHOD Size of Steel Aircraft Bolts Specification dia. (inches) Recommended Wrench Torque (in-lbs) AN6 3/8 200 +/- 25 AN7 7/16 250 +/- 25 Jan Carlsson www.jcpropellerdesign.com "SteveR" skrev i meddelandet ... Tonight I'm going to install a prop on my plane (Pietenpol with a Continental A-75) and go up for a quick flight. I've never done a prop install before, so I want to make sure I get it right. I figured I'll torque the bolts, run the plane for 10-15 minutes on the ground, check the torque, take it up for a brief test flight, then check the torque again. Any tips or things I should be careful for or watch for? I'm a little nervous as I'll be doing it without anyone looking over my shoulder. -- SteveR |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Sensenich Wood Prop Question | [email protected] | Owning | 3 | April 4th 05 02:32 PM |
Performance Designs 60 x 66 wood prop | Sam Hoskins | Aviation Marketplace | 0 | December 10th 03 01:22 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
