Hi, I would like to wire my hobbs so that it only runs when the engine is
running. Is there an oil pressure switch or something that could be used? Charlie |
Hobbs switches are a division of Stewart-Warner. Stewart-Warner parts are
available at your local NAPA Aviation Parts Store. Jim "ccwillwerth" wrote in message ... Hi, I would like to wire my hobbs so that it only runs when the engine is running. Is there an oil pressure switch or something that could be used? Charlie |
available at your local NAPA Aviation Parts Store. Jim Nicely stated, and saved. :-) Peter |
Ok!!! it's really a DATCON #102033. The meter records time. It runs from
battery power. I would like to wire it in some way so that it only operates when the engine is running. As it is now, the only thing I can figure to do is wire it to the master so that when it is on, the meter runs. This will not provide an accurate engine or airframe time, therefore, I would like to have it only run when the engine is running. Does anyone have any ideas? Charlie "ccwillwerth" wrote in message ... Hi, I would like to wire my hobbs so that it only runs when the engine is running. Is there an oil pressure switch or something that could be used? Charlie |
I used an oil pressure switch teed into the line to the oil pressure
gauge. When you turn on the master it puts power to one side of the switch and once there's pressure it closes the switch and sends power to the hourmeter. Ok!!! it's really a DATCON #102033. The meter records time. It runs from battery power. I would like to wire it in some way so that it only operates when the engine is running. As it is now, the only thing I can figure to do is wire it to the master so that when it is on, the meter runs. This will not provide an accurate engine or airframe time, therefore, I would like to have it only run when the engine is running. Does anyone have any ideas? Charlie "ccwillwerth" wrote in message .. . Hi, I would like to wire my hobbs so that it only runs when the engine is running. Is there an oil pressure switch or something that could be used? Charlie |
ccwillwerth wrote:
Ok!!! it's really a DATCON #102033. The meter records time. It runs from battery power. I would like to wire it in some way so that it only operates when the engine is running. buy this oil pressure switch: http://www.aircraftspruce.com/catalo...obbsswitch.php wire it to the Datcon and engine this way: http://www.aeroelectric.com/PPS/Engi...Oil_P_Warn.pdf The low oil pressure warning buzzer and light shown on the schematic are optional. They are not required for the Datcon hour meter function. |
| Cessna PTT switch normal? | Mark Hansen | Owning | 9 | September 23rd 06 06:12 AM |
| 74 Archer ignition switch question | Mike Noel | Owning | 9 | September 10th 06 11:46 PM |
| Cessna landing light switch; solved! | jim | Owning | 1 | January 15th 06 11:33 PM |
| What does REC mean on the switch? | Jose | Piloting | 10 | June 15th 05 06:55 AM |
| C-172 landing light switch | JFLEISC | Owning | 10 | May 6th 04 12:05 AM |
