Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Good Garmin 396 Mount - Cessna..
Old August 5th 07, 01:01 AM posted to rec.aviation.piloting,rec.aviation.products
Dan[_1_]
Default Good Garmin 396 Mount - Cessna..
All,
My flying club has a 98 Cessna 182. Unfortunately, the yoke mounted
chart clip is in the way of the standard Garmin 396 mounting bracket.
This chart clip is not removable easily enough that I'd want to remove
and re-mount it everytime I fly (it's a shared aircraft... If it were
mine, I'd just permanently remove the thing.)
I am considering the purchase of a RAM mount "RAM-B-121-GA7". Does
anyone have any experience with this thing on Cessna Yokes? Can I
come _under_ the yoke with the bracket? Do I need to order any
accessories to make it work, or will that part # include everything I
need?
This might work good on the Comanche yoke also, since I have to have
the GPS slightly tilted due to the full crossmember at the top of the
yoke, and AP disconnect/PTT "plate"...
Unfortunately, my local shop does not have the RAM part in stock, and
it's a little difficult to know for sure what to order on something
like this if you can't lay eyes on it.
Any advice is welcome.
Thanks,
Dan
Old August 6th 07, 04:31 AM posted to rec.aviation.piloting,rec.aviation.products
john smith[_2_]
In article om,
need?
I use the suction cup mount and attach it to the side of the windscreen.
This brings it up and closer to eyelevel and into my line of sight as I
look outside.
Old August 6th 07, 03:23 PM posted to rec.aviation.piloting,rec.aviation.products
Paul kgyy
I've used a suction cup mount for several years, and it mostly works
fine.
However, it has fallen off a couple of times. I would hate for that
to happen in the middle of an ifr approach so am looking for an
alternative.
Old August 7th 07, 04:19 AM posted to rec.aviation.piloting,rec.aviation.products
john smith[_2_]
In article .com,
fine.
alternative.
As long as you keep it wet, it will stay in place.
On a hot day, it may be possible for the water between the window and
the suction cup may evaporate.
Old August 6th 07, 11:13 AM posted to rec.aviation.piloting,rec.aviation.products
Cubdriver
Not quite the same, to be sure, but here are solutions for the Cub:
www.pipercubforum.com/garmin.htm
I rent, so for me the G Force suction cup has been the solution.
Blue skies! -- Dan Ford
Claire Chennault and His American Volunteers, 1941-1942
from HarperCollins on August 21 www.flyingtigersbook.com
Old August 8th 07, 05:59 AM posted to rec.aviation.piloting,rec.aviation.products
Russ and/or Martha Oppenheim
Don't know if this is comparable or not. I have a 296 and fly a rented
Cessna 152 or 172. I have a beanbag bracket which just sits on top of the
dash and holds it. It's very secure, has never fallen off, and I can use it
on what ever I'm flying.
Martha
"Dan" wrote in message
ps.com...
All,
need?
Thanks,
Dan
Old August 8th 07, 03:22 PM posted to rec.aviation.piloting,rec.aviation.products
john smith[_2_]
You don't fly in much turbulence, do you?
Even the suction cup mount can come loose when the bumps reach a given
level.
The most solid mount is the yoke mount, it remains firmly attached
during the roughest of rides.
Old August 8th 07, 03:39 PM posted to rec.aviation.piloting,rec.aviation.products
B A R R Y[_2_]
The yoke mount hits my leg.
The best mounts I've seen are Ram mounts. My current installation has
the Ram mount clamped to a support brace, holding the GPS slightly above
the glareshield at the far left side of the panel.
Old August 8th 07, 04:58 PM posted to rec.aviation.piloting,rec.aviation.products
Newps
Check out these mounts. I have one in my Bo. Absolute top of the line
quality.
http://www.angerole.com/
Old August 9th 07, 01:43 AM posted to rec.aviation.piloting,rec.aviation.products
Dave[_5_]
quality.
I saw this one on eBay - looks solid (if you have a spare instrument
hole).
http://cgi.ebay.com/ebaymotors/Garmi...QQcmdZViewItem
David Johnson
Good Garmin 396 Mount - Cessna.. Dan[_1_] Piloting 12 August 9th 07 04:33 AM
Garmin Pilot 3 yoke mount The Ponderosa Owning 1 December 13th 05 02:30 PM
manual for garmin 100 panel mount. Ray Toews Home Built 1 September 11th 05 10:28 PM
Need a Cessna 120 engine mount Jerry Aviation Marketplace 0 November 28th 04 02:16 AM
Good panel mount COM radio and intercom w/push-to-talk? John Huebbe Home Built 10 November 27th 04 07:58 PM
