Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal
on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick |
"Dick" wrote in message
news:c26ui.7629$dD3.905@trnddc07... Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick OK, I aint no A&P... but, what kind of shape is the crankshaft surface in? Is the crankcase vent flowing without obstruction? What did you use to re-install the new seal? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
no visible scratches or marks on crank; vent is flowing; slightly oiled
perimeter and pushed into engine case with wood handle of screwdriver...seal split is at about 1pm position. placing spring ends together and getting up into the seal insides was difficult.. Can I assume once up there the spring stays??? Anybody know ?? "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:OvWdnS8oJJ_7aSXbnZ2dnUVZ_rmjnZ2d@wideopenwest .com... "Dick" wrote in message news:c26ui.7629$dD3.905@trnddc07... Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick OK, I aint no A&P... but, what kind of shape is the crankshaft surface in? Is the crankcase vent flowing without obstruction? What did you use to re-install the new seal? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Aug 7, 5:56 pm, "Dick" wrote:
no visible scratches or marks on crank; vent is flowing; slightly oiled perimeter and pushed into engine case with wood handle of screwdriver...seal split is at about 1pm position. placing spring ends together and getting up into the seal insides was difficult.. Can I assume once up there the spring stays??? Anybody know ?? Should have used rubber cement (3M's 847) on the outer perimeter and in the engine case bore. The spring might have popped off if you didn't keep the split ends lined up as you pushed the seal in. Dan |
how would I get this new unglued seal out for another try? I destroyed the
old one getting it out. New one had the tightest split I had ever experienced but finally was able to push enough to get the entire seal into the bore. do you think I should go ahead and order another seal? wrote in message oups.com... On Aug 7, 5:56 pm, "Dick" wrote: no visible scratches or marks on crank; vent is flowing; slightly oiled perimeter and pushed into engine case with wood handle of screwdriver...seal split is at about 1pm position. placing spring ends together and getting up into the seal insides was difficult.. Can I assume once up there the spring stays??? Anybody know ?? Should have used rubber cement (3M's 847) on the outer perimeter and in the engine case bore. The spring might have popped off if you didn't keep the split ends lined up as you pushed the seal in. Dan |
On Aug 8, 1:28 pm, "Dick" wrote:
how would I get this new unglued seal out for another try? I destroyed the old one getting it out. New one had the tightest split I had ever experienced but finally was able to push enough to get the entire seal into the bore. do you think I should go ahead and order another seal? I wonder if a little air pressure up the breather might help that seal come out again? And then check the bore to see that there isn't some dried adhesive in there that may be interfering with the sealing of the seal against the case. But just a little pressu you don't want to start blowing gaskets or tachometer drive seals. Dan |
Continental which used the same type seal as the Lycoming and Franklin
recommends the split be at 11 or 1 o'clock.(case spilt is at 12. My recommendation is to use "super glue" on the ends. Make sure the recess is clean and dry. Use a sealer on the outside. I like Loctite 515 and remember to replace the garter spring and grease the lip. Look at Continental M76-4 for the complete Continental instructions. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A 46 Year Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "Dick" wrote in message news:c26ui.7629$dD3.905@trnddc07... Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick |
thanks for M76-4 copy and everyone's advice. am going to order another seal
and do better. "Cy Galley" wrote in message news:FVzui.55189$Fc.32497@attbi_s21... Continental which used the same type seal as the Lycoming and Franklin recommends the split be at 11 or 1 o'clock.(case spilt is at 12. My recommendation is to use "super glue" on the ends. Make sure the recess is clean and dry. Use a sealer on the outside. I like Loctite 515 and remember to replace the garter spring and grease the lip. Look at Continental M76-4 for the complete Continental instructions. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A 46 Year Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "Dick" wrote in message news:c26ui.7629$dD3.905@trnddc07... Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick |
Dick wrote:
thanks for M76-4 copy and everyone's advice. am going to order another seal and do better. "Cy Galley" wrote in message news:FVzui.55189$Fc.32497@attbi_s21... Continental which used the same type seal as the Lycoming and Franklin recommends the split be at 11 or 1 o'clock.(case spilt is at 12. My recommendation is to use "super glue" on the ends. Make sure the recess is clean and dry. Use a sealer on the outside. I like Loctite 515 and remember to replace the garter spring and grease the lip. Look at Continental M76-4 for the complete Continental instructions. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A 46 Year Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "Dick" wrote in message news:c26ui.7629$dD3.905@trnddc07... Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick Does Continental have a solid seal for the engine? The type you force over the prop flange? I've used those before and have seemed to do a good job. Just a thought. Dave |
On Aug 9, 8:08 am, Dave wrote:
Dick wrote: thanks for M76-4 copy and everyone's advice. am going to order another seal and do better. "Cy Galley" wrote in message news:FVzui.55189$Fc.32497@attbi_s21... Continental which used the same type seal as the Lycoming and Franklin recommends the split be at 11 or 1 o'clock.(case spilt is at 12. My recommendation is to use "super glue" on the ends. Make sure the recess is clean and dry. Use a sealer on the outside. I like Loctite 515 and remember to replace the garter spring and grease the lip. Look at Continental M76-4 for the complete Continental instructions. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A 46 Year Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "Dick" wrote in message news:c26ui.7629$dD3.905@trnddc07... Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal on the front of my flanged crankshaft C-85 , my first flight today still shows leakage.... Never really doing those old Chevy two part split seals well, I guess I'm still inept G. I think I'll be able to better the aforementioned time durations but would appreciate any hints at doing a better job this time. Thanks, Dick Does Continental have a solid seal for the engine? The type you force over the prop flange? I've used those before and have seemed to do a good job. Just a thought. Never seen one, at least for the small engines. That's Lycoming's method. Dan |
what am I doing wrong | gt[_2_] | Aviation Photos | 8 | June 4th 07 01:49 AM |
Wrong Vario!!! | Mike Hostage | Soaring | 0 | March 30th 05 01:39 AM |
What's wrong with this engine? | Fred the Red Shirt | Home Built | 6 | May 3rd 04 04:49 AM |
ATC says wrong position | Greg Esres | Instrument Flight Rules | 28 | April 30th 04 05:37 PM |
Saying the wrong thing...! | Paul Sengupta | Piloting | 3 | January 23rd 04 03:58 AM |
