I weighed my trailer yesterday (Sunday) at a local truck stop, using
their truck scales. 2,040 lbs total. Tongue weight is 180 lbs. Trailer: 2006 year model Swan Glider: 1970 LS1-d Extra stuff in trailer: steel wing stand, aluminum tow out gear, tail dolly, one folding aluminum chair, plastic bucket, two gallons water, 4 aluminum tie down stakes, some towels, tool box with a couple of Vice Grips and a couple of screw drivers and an assortment of collected stuff, two extra wheel chocks, and the spare tire. That turned out about 300 lbs more than I had expected. Why do I care? Just want to know when selecting my next tow vehicle that will replace the 2000 Accord. Guess this leaves out a Mini or a Miata or the mighty Deux Chevaux (ente, duck, whatever) Ray Lovinggood Carrboro, North Carolina, USA |
On Oct 29, 4:03 pm, rlovinggood wrote:
I weighed my trailer yesterday (Sunday) at a local truck stop, using their truck scales. 2,040 lbs total. Tongue weight is 180 lbs. Trailer: 2006 year model Swan Glider: 1970 LS1-d Extra stuff in trailer: steel wing stand, aluminum tow out gear, tail dolly, one folding aluminum chair, plastic bucket, two gallons water, 4 aluminum tie down stakes, some towels, tool box with a couple of Vice Grips and a couple of screw drivers and an assortment of collected stuff, two extra wheel chocks, and the spare tire. That turned out about 300 lbs more than I had expected. Why do I care? Just want to know when selecting my next tow vehicle that will replace the 2000 Accord. Guess this leaves out a Mini or a Miata or the mighty Deux Chevaux (ente, duck, whatever) Ray Lovinggood Carrboro, North Carolina, USA Mine: Speed Astir II, Komet trailer, tools and other expected support equipement. 1,836 pounds total, with 186 on the hitch. Weighed with scales used to do a weight and balance. |
Ray:
Check out Bob Carlton's article of Oct 9th. It's a few pages back. There will be lots of stuff on getting the job done with a minimum of tow veh. I think Bob has the right idea. Go for the mass. Whops, what's that I just ran over a Prius? Zulu |
... 2,040 lbs total. Tongue weight is 180 lbs. ... Wow, that's incredible. No wonder you guys buy such big cars. For comparison, my HP-11 had an empty weight of about 450 lbs with O2 and battery, and its enclosed trailer (which Steve Smith originally built for his PIK-20) weighed about 350 lbs. With assembly gear and dollies I don't think the whole rig ever saw the high side of 900 lbs. It towed quite sweetly across the Sierra behind Volvo 740 and 240, Mazda B2000 pickup, and even 1.8 liter Subaru Brat. From deconstructing several glider trailers, what I've found is that the greatest single weight contributor (next to the glider) is often the plywood flooring. On a typical 15m trailer with 26'x4' of floor area, the floor takes almost 80 lbs of 1/4" plywood, about 117 lbs of 3/8" plywood, or 156 lbs of 1/2" plywood. And I've seen two-seater trailers that used upwards of 300 lbs of 3/4" plywood flooring. The lighter trailers tend to have very thin floors, supported by many lateral underfloor elements. The aforementioned HP-11 trailer had non- structural fiberglass floor sheeting; you had to be careful to step only on the longerons or dolly rails lest your feet go all the way through to the ground. Sure, that made it a somewhat suboptimal conveyance. But it beat the hell out of buying a huge ol' tow car. Bob K. |
On Oct 30, 7:03 pm, Bob Kuykendall wrote:
On Oct 29, 4:03 pm, rlovinggood wrote: ... 2,040 lbs total. Tongue weight is 180 lbs. ... Wow, that's incredible. No wonder you guys buy such big cars. For comparison, my HP-11 had an empty weight of about 450 lbs with O2 and battery, and its enclosed trailer (which Steve Smith originally built for his PIK-20) weighed about 350 lbs. With assembly gear and dollies I don't think the whole rig ever saw the high side of 900 lbs. It towed quite sweetly across the Sierra behind Volvo 740 and 240, Mazda B2000 pickup, and even 1.8 liter Subaru Brat. From deconstructing several glider trailers, what I've found is that the greatest single weight contributor (next to the glider) is often the plywood flooring. On a typical 15m trailer with 26'x4' of floor area, the floor takes almost 80 lbs of 1/4" plywood, about 117 lbs of 3/8" plywood, or 156 lbs of 1/2" plywood. And I've seen two-seater trailers that used upwards of 300 lbs of 3/4" plywood flooring. The lighter trailers tend to have very thin floors, supported by many lateral underfloor elements. The aforementioned HP-11 trailer had non- structural fiberglass floor sheeting; you had to be careful to step only on the longerons or dolly rails lest your feet go all the way through to the ground. Sure, that made it a somewhat suboptimal conveyance. But it beat the hell out of buying a huge ol' tow car. Bob K. To further Bob's point, the floor in a Cobra trailer is a light-weight sandwich. They offer a heavier (and much cheaper) floor, but nobody buys it. Other trailers cost less but weigh more... |
160-180 lbs nose weight sounds a lot. About 100 would be my preference
for stability, 50 or less to make it easier to manhandle but with some sacrifice of stability. According to my car handbook, max permitted nose weight is determined by the manufacturer of the bar (tongue) on the front of the trailer. In my case (Lak 17), that is 100 kilograms or 220 lbs, but I would not load it up at the front anything like that heavily. Chris N. |
On Oct 31, 4:20 am, wrote:
160-180 lbs nose weight sounds a lot. About 100 would be my preference for stability, 50 or less to make it easier to manhandle but with some sacrifice of stability... Just as a reference point, while using glider trailers to haul molds and tooling around I've occasionally had to drive long distance with zero tongue weight. Stability didn't seem to be a problem at all, though I was pretty constantly worried about having the tongue lift off the tow ball. We checked it often. |
160-180 lbs nose weight sounds a lot. About 100 would be my preference for stability, 50 or less to make it easier to manhandle but with some sacrifice of stability... Just as a reference point, while using glider trailers to haul molds and tooling around I've occasionally had to drive long distance with zero tongue weight. Stability didn't seem to be a problem at all, though I was pretty constantly worried about having the tongue lift off the tow ball. We checked it often. My Anschau trailer (for a single seater) is placarded: "Tongue weight 4%, more than 25kg not nessecairy." |
| Thread Tools | |
| Display Modes | |
| Max weight of K21 | t-tree | Soaring | 0 | February 3rd 07 10:43 AM |
| How much does an IO-540 weight, wet? | iliad | Home Built | 2 | June 11th 06 03:19 PM |
| Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 10:26 PM |
| Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 05:20 AM |
| weight | David Smith | Soaring | 4 | December 19th 03 04:34 PM |
