Altimeter Question
Old April 17th 08, 11:20 AM posted to rec.aviation.piloting,rec.aviation.student
terry
Default Altimeter Question
I am confused by this practice commercial nav question. ( at least I
am confused by the answer in the book which was b. but I think both a
and c are correct), but I appreciate some other opinions.
Day 1 Altimeter reads elevation of 1390 feet with 1013 HPa set on
subscale
( thats equivalent to 29.92 inches of Hg for the US folks)
Day 2 Altimeter reads elevation of 1000 feet
Assuming the altimeter subscale was not changed between day 1 and day
2 it could be said that
a. The QNH is higher on day 2
b. The QNH is lower on day 2
c. The pressure altitude at the airport is lower on day 2
d. The atmospheric pressure at the aerodrome has not changed.
Terry
PPL Downunder
Old April 17th 08, 01:29 PM posted to rec.aviation.piloting,rec.aviation.student
Mortimer Schnerd, RN[_2_]
subscale
Their answer confuses me too. It seems that if the altimeter setting wasn't
changed from day 1 to day 2, yet it reads a lower altitude, the barometric
pressure must have risen. The altimeter will translate lower pressure to higher
altitude and higher pressure to lower altitude. So I think the answer should be
"a". And if I accept "a", I have to accept "c" as well, as you did.
I'm probably going to regret posting this because I'm going off the top of my
head but it wouldn't be the first time a test guide had the wrong answer posted.
Alright guys.... pile on!
mschnerdatcarolina.rr.com
Old April 17th 08, 01:42 PM posted to rec.aviation.piloting,rec.aviation.student
terry
On Apr 17, 9:29*pm, "Mortimer Schnerd, RN" mschnerdatcarolina.rr.com
subscale
* * * * ( thats equivalent to 29.92 inches of Hg for the US folks)
d. *The atmospheric pressure at the aerodrome has not changed.
Their answer confuses me too. *It seems that if the altimeter setting wasn't
pressure must have risen. *The altimeter will translate lower pressure to higher
altitude and higher pressure to lower altitude. *So I think the answer should be
"a". *And if I accept "a", I have to accept "c" as well, as you did.
No, its not the first time I have come across wrong answers either,
but it is the first time I have come across a wrong answer, pointed it
out to the author and was still told I was wrong. ( I dont want to
name the said author because I think he otherwise has published some
very good material and I am sure he will soon realise his mistake.. I
just wanted to be absolutely sure I was right before I responded to
his response!)
Thanks Mort
Old April 17th 08, 01:30 PM posted to rec.aviation.piloting,rec.aviation.student
Barry
subscale
I agree with you - answers a and c are both correct. Day 2 QNH is about 1026.
terry
subscale
I agree with you - answers a and c are both correct. *Day 2 QNH is about 1026.
Yep, thats what I get
Thanks
Old April 17th 08, 03:38 PM posted to rec.aviation.piloting,rec.aviation.student
Stealth Pilot[_2_]
subscale
playing with an altimeter here in my lap.
simulating 1390 by setting 390. the qnh reads as 1032.
moving the needle lower sees the qnh values going lower.
so to correct for the reduced reading I would need to move the qnh the
other way.(increase it)
I agree a is correct from playing with an actual altimeter.
c is correct just from reading the data in the question.
fwiw
Stealth pilot
Old April 17th 08, 03:51 PM posted to rec.aviation.piloting,rec.aviation.student
terry
On Apr 17, 11:38*pm, Stealth Pilot
subscale
fwiw
Stealth pilot- Hide quoted text -
gday Stealth,
I just think of an altimeter as being a inverse pressure guage cos
pressure decreases with altitude, so for altitude reading to have gone
down , atmospheric pressure has to have gone up.
I gotta ask, why have you got an altimeter in your lap?
Terry
Old April 18th 08, 03:07 PM posted to rec.aviation.piloting,rec.aviation.student
Stealth Pilot[_2_]
On Thu, 17 Apr 2008 06:51:24 -0700 (PDT), terry
subscale
fwiw
gday Stealth,
Terry
that's like the goon show joke. turn the knob on your side.
but I dont have a knob on my side. ...there's one on the door though.
anyway it is the old altimeter out of my auster restoration. it lives
with a few other instruments in the cupboard behind me as I type.
Old April 17th 08, 02:57 PM posted to rec.aviation.piloting,rec.aviation.student
Larry Dighera
On Thu, 17 Apr 2008 02:20:46 -0700 (PDT), terry
wrote in
subscale
http://en.wikipedia.org/wiki/Mbar
Atmospheric air pressure is often given in millibars where
"standard" sea level pressure is defined as 1013.25 mbar (hPa),
equal to 1.01325 bar. Despite millibars not being an SI unit, they
are still used locally in meteorology in some countries to
describe atmospheric pressure. The SI unit is the pascal (Pa),
with 1 mbar = 100 Pa = 1 hPa = 0.1 kPa. Meteorologists worldwide
have long measured air pressure in millibars. After the
introduction of SI units, others use hectopascals (which are
equivalent to millibars) so they could stick to the same numeric
scale. Similar pressures are given in kilopascals in practically
all other fields, where the hecto prefix is hardly ever used. In
particular, Canadian weather reports use kilopascals (which could
also be called centibars).
Terry
PPL Downunder
http://www.acronymfinder.com/acronym.aspx?rec={8F1A7DDE-89E8-11D4-8351-00C04FC2C2BF}
What does QNH stand for?
Atmospheric Pressure (Q) at Nautical Height (aviation)
Old April 17th 08, 03:29 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
Mbar would be a tad much. You certainly meant mbar.
Bull****. QNH is *not* an acronym. It's one of over hundred Q-Codes
which were defined in the stone age of radio telephony. The letters were
randomly chosen, think of it as a numeration. Most of those Q-Codes are
forgotten today, but a few still live. In aviation, I mean in aviation
in all coutries except the USA, QNH, QFE and QNH are used to define
different altitude settings (roughly spoken).
QNH stands for the pressure you must tune in the kollmans window to have
the altimeter display the airport elevation when the airplane sits on
the ground. (As opposed to QFE, which ist the pressure to set for the
alitmeter to display zero on the ground and QNE, which is the altitude
which the alitmeter shows on the ground when it is set to standard
atmosphere.)
For those who believe in Wikipedia: http://en.wikipedia.org/wiki/Q-code
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 04:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 01:11 PM
Altimeter discrepancy Gene Whitt Instrument Flight Rules 6 August 1st 05 08:11 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 09:07 PM
Altimeter Disassembly Dick Home Built 3 April 2nd 05 02:27 PM
