Welded Patch Repair question
Old July 19th 08, 04:08 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Welded Patch Repair question
I'm working with 4130.
I have a piece of tubing with a series of rust holes which do not
cover an area greater than 1/2 ", so it appears a welded patch repair
would be appropriate.
Reading 43.13,, Figure 4-36, it appears the patch tube will have to be
expanded in diameter in order to fit over the injured tube (can't slip
the patch over the injured tubefrom an end).
Will there be any problem if I heat the patch so I can open open it
and slip it over the injured tubing? - Mike
Old July 19th 08, 08:14 PM posted to rec.aviation.homebuilt
Bruce A. Frank
You should use the next diameter of tube to get easy conformation the the shape of the tube you are repairing. But, if you have no choice but  to use a patch from the same diameter tube, there is no problem with heating the patch to make it plastic enough to conform to the outside contour of the tube being repaired. If it doesn't lay down smoothly you can tack welt the patch where it makes contact with the tube, then heat the patch with the torch and gently tap it into place, till it lies down tightly with the tube, with a small hammer. You can tap and tack as you go until the patch is a tight fit, the weld it.
If you want to make a slip over repair using a whole piece of tube, you will have to use the next diameter tube as it would be virtually impossible to expand the diameter of a tube uniformly and continuously around its circumference.
Michael Horowitz wrote: I'm working with 4130.
Old July 19th 08, 10:58 PM posted to rec.aviation.homebuilt
Michael Horowitz
Bruce - can't open it. Recommendation? - MIke
On Sat, 19 Jul 2008 19:14:38 GMT, "Bruce A. Frank"
Old July 20th 08, 10:43 AM posted to rec.aviation.homebuilt
Bruce A. Frank
Michael Horowitz wrote: Bruce - can't open it. Recommendation? - MIke
Old July 20th 08, 03:41 PM posted to rec.aviation.homebuilt
Michael Horowitz
Nevermind; got it - Mike\
On Sat, 19 Jul 2008 17:58:18 -0400, Michael Horowitz
Old July 19th 08, 11:01 PM posted to rec.aviation.homebuilt
Michael Horowitz
Old July 19th 08, 11:14 PM posted to rec.aviation.homebuilt
Michael Horowitz
Old July 22nd 08, 08:34 AM posted to rec.aviation.homebuilt
Bruce A. Frank
I know you said you got it, but I figured out how to make some changes
in the program and wonder it it shows up now:
to use a patch from
Old July 28th 08, 03:07 AM posted to rec.aviation.homebuilt
Highflyer
"Michael Horowitz" wrote in message
No problem. Use the next size larger tubing. Run it through the bandsaw
lengthwise. Fix it over the damaged tube and weld everything back together.
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
Old July 28th 08, 04:04 AM posted to rec.aviation.homebuilt
Morgans[_2_]
together.
How about cutting a taper (like points on opposite sides from each other) on
the new tube to avoid creating a stress riser that would occur where the new
tube suddenly stopped, all of the way around?
Jim in NC
Stressed Skin Repair Question RPM the A&P Home Built 9 July 16th 08 04:59 AM
4130 can't be OA welded? wright1902glider Home Built 61 January 4th 08 05:19 AM
Magneto Repair vs Overhaul Question. Ebby Home Built 6 February 24th 07 05:55 PM
172 Repair question Brad Mallard Home Built 2 June 11th 04 02:54 AM
172 Repair question Brad Mallard Aviation Marketplace 3 June 11th 04 02:54 AM
