I've noticed that my prop is beginning to show signs of wear -chips in the
leading edge, and cracks in the clear finish. Given that I'm having shoulder surgery in a couple of weeks (and probably won't be up to flying until the arm is substantially healed), I should have some time on my hands to refinish the prop. My plan is to remove the existing finish by sanding with ~220 grit sandpaper, then to use epoxy (with cabosil?) to fill any dents, etc, and sand/scrape the repaired areas back to the appropriate profile. Also, I plan on doing some repair work to the leading edge which is an epoxy based product. On the leading edge, I'll probably grind into any damaged areas, then fill with one of the putty type epoxies and sand/scrape to the correct profile, finishing with a very fine sandpaper. Finally, I'll check the balance of the prop before finishing, and adjust balance by either a little more sanding on the heavy blade or an extra coat or two of urethane on the light blade. What steps have I missed, and are there any fine points I'm missing? Thanks in advance, Kyle |
![]() "Kyle Boatright" wrote in message . .. I've noticed that my prop is beginning to show signs of wear -chips in the leading edge, and cracks in the clear finish. Given that I'm having shoulder surgery in a couple of weeks (and probably won't be up to flying until the arm is substantially healed), I should have some time on my hands to refinish the prop. Don't know what brand of prop you have, but the manufacturer should have some guidance available. Sensenich provides the following: http://www.sensenichprop.com/sen_htm...stall/cf-a.pdf My plan is to remove the existing finish by sanding with ~220 grit sandpaper, then to use epoxy (with cabosil?) to fill any dents, etc, and sand/scrape the repaired areas back to the appropriate profile. Also, I plan on doing some repair work to the leading edge which is an epoxy based product. On the leading edge, I'll probably grind into any damaged areas, then fill with one of the putty type epoxies and sand/scrape to the correct profile, finishing with a very fine sandpaper. Finally, I'll check the balance of the prop before finishing, and adjust balance by either a little more sanding on the heavy blade or an extra coat or two of urethane on the light blade. On the Sensenich web site "repair info" page, it states that they repair props IAW AC43.13-1B, so you might check it out (under wood repair and finishing.) Also they Care and Feeding doc (above link) says that they use spar varnish for the finish. Gerry |
On Jul 30, 6:47 pm, "Kyle Boatright" wrote:
Hey, Kyle... Don't laugh, but give JB Weld a try :-) Yeah, I know... hell of a ding. Big enough so that we're talking real divots here. The patch had to have some serious structural strength. Used a dental pick to create a key, added the JB Weld in three applications, about twenty minutes apart, coarsely finished with a rasp between layers 1-2 & 2-3. Let it cure about a week. Use the water trick to make sure you've got the contour right. (ie, arrange the thing so a flow of water across the divot catches the light, tells you when there's no difference in contour between the original surface and the divot. Use a sponge. W&D paper on a stick.) All cleaned up (your FINGERS are more accurate than your eyes), you can return the balance to near-zero by tapping lead foil into a drilling on the tip, to zero-zero with PAINT when you blacken the back-side. I'm sorry to hear about the arm but damn happy to know it isn't catching :-) -Bob |
On Jul 31, 9:19*am, " wrote:
On Jul 30, 6:47 pm, "Kyle Boatright" wrote: Hey, Kyle... Don't laugh, but give JB Weld a try :-) Yeah, I know... hell of a ding. *Big enough so that we're talking real divots here. *The patch had to have some serious structural strength. Used a dental pick to create a key, added the JB Weld in three applications, about twenty minutes apart, coarsely finished with a rasp between layers 1-2 & 2-3. *Let it cure about a week. Use the water trick to make sure you've got the contour right. *(ie, arrange the thing so a flow of water across the divot catches the light, tells you when there's no *difference in contour between the original surface and the divot. *Use a sponge. *W&D paper on a stick.) *All cleaned up (your FINGERS are more accurate than your eyes), you can return the balance to near-zero by tapping lead foil into a drilling on the tip, to zero-zero with PAINT when you blacken the back-side. I'm sorry to hear about the arm but damn happy to know it isn't catching :-) -Bob I don't know what part of the countryyou live in Kyle but if you were close to TN I'd make a trip to your homebase and help out just to pull a mold off half of your prop. :-).FWIW don't rule out having a local E.A.A. chapter member that's into prop building hellping you out in exchange for the opputunity to make a duplicate of your prop. Joe |
![]() "Copperhead144" wrote in message ... On Jul 31, 9:19 am, " wrote: On Jul 30, 6:47 pm, "Kyle Boatright" wrote: Hey, Kyle... Don't laugh, but give JB Weld a try :-) Yeah, I know... hell of a ding. Big enough so that we're talking real divots here. The patch had to have some serious structural strength. Used a dental pick to create a key, added the JB Weld in three applications, about twenty minutes apart, coarsely finished with a rasp between layers 1-2 & 2-3. Let it cure about a week. Use the water trick to make sure you've got the contour right. (ie, arrange the thing so a flow of water across the divot catches the light, tells you when there's no difference in contour between the original surface and the divot. Use a sponge. W&D paper on a stick.) All cleaned up (your FINGERS are more accurate than your eyes), you can return the balance to near-zero by tapping lead foil into a drilling on the tip, to zero-zero with PAINT when you blacken the back-side. I'm sorry to hear about the arm but damn happy to know it isn't catching :-) -Bob I don't know what part of the countryyou live in Kyle but if you were close to TN I'd make a trip to your homebase and help out just to pull a mold off half of your prop. :-).FWIW don't rule out having a local E.A.A. chapter member that's into prop building hellping you out in exchange for the opputunity to make a duplicate of your prop. Joe I'm based at VPC - Cartersville, GA, which is about 30 miles NW of Hartsfield Jackson. I live right off I-75 in Marietta, just outside the perimeter highway for Atlanta... If you're still interested in making a mold, drop me a line. By the way, what does one do with a prop mold? KB |
On Jul 31, 5:40*pm, "Kyle Boatright" wrote:
"Copperhead144" wrote in message .... On Jul 31, 9:19 am, " wrote: On Jul 30, 6:47 pm, "Kyle Boatright" wrote: Hey, Kyle... Don't laugh, but give JB Weld a try :-) Yeah, I know... hell of a ding. Big enough so that we're talking real divots here. The patch had to have some serious structural strength. Used a dental pick to create a key, added the JB Weld in three applications, about twenty minutes apart, coarsely finished with a rasp between layers 1-2 & 2-3. Let it cure about a week. Use the water trick to make sure you've got the contour right. (ie, arrange the thing so a flow of water across the divot catches the light, tells you when there's no difference in contour between the original surface and the divot. Use a sponge. W&D paper on a stick.) All cleaned up (your FINGERS are more accurate than your eyes), you can return the balance to near-zero by tapping lead foil into a drilling on the tip, to zero-zero with PAINT when you blacken the back-side. I'm sorry to hear about the arm but damn happy to know it isn't catching :-) -Bob I don't know what part of the countryyou live in Kyle but if you were close to TN I'd make a trip to your homebase and help out just to pull a mold off half of your prop. :-).FWIW don't rule out having a local E.A.A. chapter member that's into prop building hellping you out in exchange for the opputunity to make a duplicate of your prop. Joe I'm based at VPC - Cartersville, GA, which is about 30 miles NW of Hartsfield Jackson. *I live right off I-75 in Marietta, just outside the perimeter highway for Atlanta... If you're still interested in making a mold, drop me a line. *By the way, what does one do with a prop mold? KB- Hide quoted text - - Show quoted text - Hmmm! Your about a three hour drive from my location, let me check my schedule and I'll get an e-mail to you. Now, with regard's to a mold of the prop, you use the split mold to cast a copy of the mold, smooth it up if necessary and then use it as a master in a propeller duplicator. Or at least I hope so any way, I'm researching the heck out of prop building and mapping out plans for a propeller duplicator. Blame it all on Bob Hoover, he's got me believing I can do the impossible. :-). It's nice when people encourage you to try new things and reachout a bit further isn't it? Joe |
On Jul 31, 10:19 am, " wrote:
On Jul 30, 6:47 pm, "Kyle Boatright" wrote: Hey, Kyle... Don't laugh, but give JB Weld a try :-) Yeah, I know... hell of a ding. Big enough so that we're talking real divots here. The patch had to have some serious structural strength. Used a dental pick to create a key, added the JB Weld in three applications, about twenty minutes apart, coarsely finished with a rasp between layers 1-2 & 2-3. Let it cure about a week. Use the water trick to make sure you've got the contour right. (ie, arrange the thing so a flow of water across the divot catches the light, tells you when there's no difference in contour between the original surface and the divot. Use a sponge. W&D paper on a stick.) All cleaned up (your FINGERS are more accurate than your eyes), you can return the balance to near-zero by tapping lead foil into a drilling on the tip, to zero-zero with PAINT when you blacken the back-side. I'm sorry to hear about the arm but damn happy to know it isn't catching :-) -Bob Just a nit to pick on here. The "back" side of a prop is the side the pilot cannot see The "front" side of a prop is the side that you should "blacken" JimV. |
On Sat, 9 Aug 2008 21:08:23 -0700 (PDT), dpilot
wrote: On Jul 31, 10:19 am, " wrote: On Jul 30, 6:47 pm, "Kyle Boatright" wrote: Hey, Kyle... Don't laugh, but give JB Weld a try :-) Yeah, I know... hell of a ding. Big enough so that we're talking real divots here. The patch had to have some serious structural strength. Used a dental pick to create a key, added the JB Weld in three applications, about twenty minutes apart, coarsely finished with a rasp between layers 1-2 & 2-3. Let it cure about a week. Use the water trick to make sure you've got the contour right. (ie, arrange the thing so a flow of water across the divot catches the light, tells you when there's no difference in contour between the original surface and the divot. Use a sponge. W&D paper on a stick.) All cleaned up (your FINGERS are more accurate than your eyes), you can return the balance to near-zero by tapping lead foil into a drilling on the tip, to zero-zero with PAINT when you blacken the back-side. I'm sorry to hear about the arm but damn happy to know it isn't catching :-) -Bob Just a nit to pick on here. The "back" side of a prop is the side the pilot cannot see The "front" side of a prop is the side that you should "blacken" JimV. only on a pusher.... |
On Sun, 10 Aug 2008 20:27:24 +0800, Stealth Pilot
wrote: Just a nit to pick on here. The "back" side of a prop is the side the pilot cannot see The "front" side of a prop is the side that you should "blacken" only on a pusher.... Jim should have used "Face" instead of "Front," but the "Back" side of the blade is indeed the side the pilot cannot see. Think relative wind. When the engine is turning the prop on a tractor engine, the side the pilot CAN see is the side that is impacted by the oncoming air. Only when the engine is windmilling does the relative wind hit the side of the blade seen from in front. This is a boat site, but it illustrates the issue: http://www.propline.com/Propeller-Ge...erminology.htm Ron Wanttaja |
On Jul 30, 6:47*pm, "Kyle Boatright" wrote:
(snip) What steps have I missed, and are there any fine points I'm missing? Kyle .......... Shoulder surgery, hmmm. . . I remember three months after mine I was finally able to lift my arm enough to wash underneath without using a stick. Good luck on the sanding! I used an electric random orbiltal on my Sterba prop and was surprised at the irregularities in the surface. I just kept at it until all the original varnish was gone and the last dip was sanded smooth, then finished up to a 320 grit. I figured that all that sanding might either improve the efficiency or thin the airfoil enough to increase the rpm a bit. Neither one happened - I couldn't tell a bit of difference. The leading edge on a Sterba prop is made from a softer urethane material that resists dings and it didn't need repair. Some tips on wood prop maintenance are available he http://www.greatplainsas.com/edmtce.html When I was satisfied with the quality of the spray can urethane finish, I made a steel "spud" that fit the center hole. I constructed a wood jig in the shape of a "U", cut two grooves in the top edges and inserted two extra blades from my jointer. Then I could lay the prop in the jig with the spud resting on the sharp edge of the jointer blades. One extra coat on one blade of the prop and it balanced. Rich S. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Wood Prop Question | [email protected] | Home Built | 0 | April 18th 07 10:01 AM |
Wood Prop Question | [email protected] | Home Built | 0 | April 18th 07 05:42 AM |
Refinishing wooden prop | Wallace Berry | Home Built | 4 | December 17th 05 03:10 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
