Wood Prop Question
Old April 18th 07, 10:01 AM posted to rec.aviation.homebuilt
Default Wood Prop Question
cavelamb himself wrote:
I believe most of those old wood props had a brass leading edge
cover.
That ought to protect the wood from rain erosion.
KB wrote:
I'm 99% sure that the props I'm talking about didn't have brass
leading
edges. The next time you're at an airshow where a Spitfire is on
display,
take a close look at the prop. On many (most?, all?) the prop is
wood, and
you can't see a transition between a brass leading edge and the wood
blade.
I've done this inspection several times at Osh and SnF...
The props at Osh are replacements for fair weather display.
The original props were for life-&-death combat in european
rainy weather.
== Chris Glur.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Wood Prop Question [email protected] Home Built 0 April 18th 07 05:42 AM
Wood Prop Question Kyle Boatright Home Built 9 April 10th 07 08:25 PM
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 02:32 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
