Glider electrics etc
Old February 6th 20, 11:38 AM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
Default Glider electrics etc
At 00:24 06 February 2020, Martin Gregorie wrote:
On Wed, 05 Feb 2020 22:06:34 +0000, Tim Newport-Peace wrote:
At 19:52 05 February 2020, Martin Gregorie wrote:
On Wed, 05 Feb 2020 18:04:13 +0000, Benedict Smith wrote:
At 16:34 05 February 2020, Martin Gregorie wrote:
On Wed, 05 Feb 2020 14:29:32 +0000, Tim Newport-Peace
I realise having an inline Belling-Lee connector isn't ideal, the
more so
as it only connects to a 50cm extension with a BNF plug on the
radio end.
This setup was in the Libelle when I bought it, seems to work
OK, and so
it has stayed there. The short extension is necessary because
otherwise
the cable wouldn't reach the radio, let alone allow the panel to
slide
out far enough to connect or disconnect it from the radio.
I've thought about replacing it, but the free end of the original
cable
is in under the front coaming, too short to reach daylight. I'm
not keen
on making a solder joint in there, which would probably be no
better
electrically than leaving the Belling-Lee in place. Last but not
least, I
don't fancy pulling and replacing the entire cable either.
If the connector doesn’t need to come apart then you could simply
wrap
it in a couple of turns of self amalgamating tape, that would be
totally
waterproof and airtight, also it can be cut off if you did need to
disconnect it.
Ben.
Sounds good to me. Thanks.
Martin | martin at Gregorie | gregorie dot org
I have always prefered Internally-Glued Heat-Shrink over Tape.
But getting back to the original posting, we should never recommend
Belling-Lee and only use where there is no alternative.
Tim Newport-Peace
http://www.newportpeace.co.uk/icom.htm
Agreed - obviously an extra 50cm of uncut cable with just a BNF on the
end would be a lot better, but, as I said, I really don't want to mess
about with soldering etc in mid-air on a piece of cable that comes out
near the front end of the right side instrument panel support channel.
However, if you can point me at a description of how to to use
'Internally-Glued Heat-Shrink over Tape' after, presumably, soldering the
internal wire ends together, that would be interesting to know. Would it
be easier than making upo some sort of clip to lock the B-L halves
together?
I had in mind sleving the Belling Lee with Heatshrink and the internal glue
will seal to the outer of the co-ax eat each end. That should be
moisture-proof. I would Never suggest splicing co-ax.
However, another possible solution would be to use:
https://tinyurl.com/tseyff8 or similar. No Soldering required.
I don't particularly like these, but I like Belling Lee even less. At least
you will be using a 50Ohm connector which is moisture proof.
Tim Newport-Peace
Old February 6th 20, 01:28 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
glue will seal to the outer of the co-ax eat each end. That should be
Ah Ha! A simple fix that never occurred to me.
Sticky heat-shrink ordered.
Thanks.
Martin | martin at
Old February 6th 20, 02:19 PM posted to rec.aviation.soaring
Thanks.
Martin | martin at
Don't be in too much of a hurry. Let the warmer weather(?) dry out any
moisture present or you will just be sealing the moisture in ;¬)
Tim Newport-Peace
Old February 6th 20, 03:50 PM posted to rec.aviation.soaring
Are you talking about a a disconnect on a wire going to a GPS antenna ?
Sorry about my ignorance regarding anything electrical.
Dan
Old February 6th 20, 04:54 PM posted to rec.aviation.soaring
No, we're talking abut the radio antenna.
Martin | martin at
Old February 6th 20, 05:32 PM posted to rec.aviation.soaring
Thanks !
What about cutting and reconnecting (quick disconnect) the GPS antenna wires. What connector would you use ?
Dan
Old February 6th 20, 06:12 PM posted to rec.aviation.soaring
Dan Marotta
On GPS antennae, for what it's worth:
I opened a GPS puck antenna used for my PowerFlarm Portable, unsoldered
the wires, cut the coax to the required length and soldered the center
conductor and shield to the correct locations. I often had GPS dropouts
on the Flarm.Â* I recently removed that antenna and, using the internal
antenna on the portable unit, have had no more drop outs.Â* Just sayin'...
On 2/6/2020 10:32 AM, wrote:
Thanks !
Dan
Dan, 5J
Old February 6th 20, 09:38 PM posted to rec.aviation.soaring
On Thu, 06 Feb 2020 09:32:50 -0800, crosscountryboxco wrote:
Thanks !
I suppose that depends on what you're connecting the GPS antenna to and
what sort of connection it uses.
My RedBox FLARM has a BNF socket for the GPS puck connection. The
supplied puck had way to much wire for my installation, so I cut the wire
on a Gilsson puck down to 150mm (6") and soldered a right-angle BNF plug
onto it. The FLARM system works perfectly.
OTOH my EW logger uses a small brass? gold-plated? screw-on antenna
connection. I didn't have ant replacements, so this time I wound the
excess cable up into a neat 'donut' secured with a couple of cable ties,
clipped the supplied ferrite core over the logger end, connected it all
up and again it works very well.
Martin | martin at
Old February 6th 20, 10:40 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Thanks for pointing to my presentation on wiring at http://aviation.derosaweb.net/presentations/#wiring. Please let me know if there are corrections to be made (and there are ALL-WAYS corrections to be made).
Also, not to toot my own horn too loudly, but I will be speaking on this topic at the 2020 SSA Convention in Little Rock, Arkansas on Saturday, Feb 22 at 1:30PM in Ballroom B. I really don't want to find myself speaking only to the hotel security staff so I truly hope to see and meet all of you there!
- John DeRosa OHM Ω
Twin electrics jan olieslagers[_2_] Home Built 2 February 5th 10 07:45 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Wind/Solar Electrics ??? RST Engineering Owning 166 December 31st 05 02:38 AM
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 04:52 AM
