Glider electrics etc
Old February 5th 20, 10:21 AM posted to rec.aviation.soaring
Colin Roney
Default Glider electrics etc
I admit I am a total dummy when it comes to glider
electrics and navigation installation stuff but I am very keen
to try and correct the situation. Does anyone have any
ideas for suggested reading in order to try and understand
the subject.
Old February 5th 20, 11:32 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Wed, 05 Feb 2020 10:21:13 +0000, Colin Roney wrote:
I admit I am a total dummy when it comes to glider electrics and
navigation installation stuff but I am very keen to try and correct the
situation. Does anyone have any ideas for suggested reading in order to
try and understand the subject.
I'll be at the club this Saturday (AM LPA duty) if the airfield is dry
enough to be usable. We can talk then if that suits you and I can bring
my panel up as well if you'd like to look at it.
When I got my Libelle, I rebuilt its panel so that:
- The panel is easy to remove from the glider.
- It connects to the power lead from the battery via an XLR plug.
The radio-related connections to a PTT on the stick and mic +
speaker on the cockpit sidewall use small round connectors with
retaining screw rings. The antenna has a Belling-Lee flying
connector to the built-in glider antenna cable.
Lastly, I use a quick-disconnect on the pneumatics (static, TE, pitot).
- I used XLR connectors for all main power connections.
- I fitted quick-blow fuses at the battery and at the panel.
- Everything in the panel that uses power has connectors (D-9 or D-15)
so that any instrument can be removed without cutting wires or
(un)soldering.
- all interconnects and the 12v-5v converter, which powers the Medion
PNA that runs LK8000, are inside a small metal box with ferrites on
the power lead for the PNA.
- once all instruments are out, the remaining wiring can also be removed
without cutting wires or unsoldering.
- NO BARE CONTACTS visible.
The ASW-20 I used to have was a nightmare behind the panel, with all
connectors soldered onto a couple of tag strips which were not easily
removable, had no insulation whatever and were was not labelled. There
were no fuses on the panel. I learned what not to do from that and got
some better ideas, especially having an interconnection box from looking
at Alan Head's neat wiring in his glider.
Martin | martin at
Gregorie | gregorie dot org
Old February 5th 20, 02:29 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
Snip
I would argue very much against the use of Belling-Lee connectors. For a
start they are not Moisture-Proof and moisture between inner and outer
conductors gives ****-poor performance.
Use BNC (or TNC) antenna connectors assuming your cable is UR43 or similar.
But whatever you use, it must provide an air-tight seal, connected or not.
Old February 5th 20, 04:34 PM posted to rec.aviation.soaring
the situation. Does anyone have any ideas for suggested reading in
order to try and understand the subject.
Snip
similar.
not.
I realise having an inline Belling-Lee connector isn't ideal, the more so
as it only connects to a 50cm extension with a BNF plug on the radio end.
This setup was in the Libelle when I bought it, seems to work OK, and so
it has stayed there. The short extension is necessary because otherwise
the cable wouldn't reach the radio, let alone allow the panel to slide
out far enough to connect or disconnect it from the radio.
I've thought about replacing it, but the free end of the original cable
is in under the front coaming, too short to reach daylight. I'm not keen
on making a solder joint in there, which would probably be no better
electrically than leaving the Belling-Lee in place. Last but not least, I
don't fancy pulling and replacing the entire cable either.
Martin | martin at
Old February 5th 20, 06:04 PM posted to rec.aviation.soaring
Benedict Smith
more so
radio end.
OK, and so
otherwise
slide
cable
not keen
better
least, I
If the connector doesn’t need to come apart then you could simply
wrap it in a couple of turns of self amalgamating tape, that would
be totally waterproof and airtight, also it can be cut off if you did
need to disconnect it.
Ben.
Old February 5th 20, 07:52 PM posted to rec.aviation.soaring
more so
radio end.
OK, and so
otherwise
slide
cable
not keen
better
least, I
If the connector doesn’t need to come apart then you could simply wrap
it in a couple of turns of self amalgamating tape, that would be totally
waterproof and airtight, also it can be cut off if you did need to
disconnect it.
Ben.
Sounds good to me. Thanks.
Martin | martin at
Old February 5th 20, 11:55 AM posted to rec.aviation.soaring
Dan Daly[_2_]
the subject.
The best I've seen is John DeRosa's http://aviation.derosaweb.net/presentations/#wiring . A lot of other great content on his site.
Dan
Old February 5th 20, 04:39 PM posted to rec.aviation.soaring
the subject.
Perhaps not an introduction, but reading selected sections of AC43.13 -1 and -2 is a fair knowledge base.
I'd also second John DeRosa's web site.
Old February 5th 20, 10:05 PM posted to rec.aviation.soaring
2G
the subject.
The FAA has several aviation maintenance technician handbooks that are excellent and, better yet, they're FREE:
https://www.faa.gov/regulations_poli...uals/aircraft/
Ch. 12 of the general handbook and Ch. 9 of Vol. 1 cover electrical subjects.
Tom
Old February 6th 20, 10:40 PM posted to rec.aviation.soaring
Thanks for pointing to my presentation on wiring at http://aviation.derosaweb.net/presentations/#wiring. Please let me know if there are corrections to be made (and there are ALL-WAYS corrections to be made).
Also, not to toot my own horn too loudly, but I will be speaking on this topic at the 2020 SSA Convention in Little Rock, Arkansas on Saturday, Feb 22 at 1:30PM in Ballroom B. I really don't want to find myself speaking only to the hotel security staff so I truly hope to see and meet all of you there!
- John DeRosa OHM Ω
Twin electrics jan olieslagers[_2_] Home Built 2 February 5th 10 07:45 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Wind/Solar Electrics ??? RST Engineering Owning 166 December 31st 05 02:38 AM
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 04:52 AM
