PowerFlarm still picking up Transponder
Old June 2nd 20, 11:29 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Default PowerFlarm still picking up Transponder
I used the PowerFlarm config tool v1.2.5 because that is what came up on a search for it. LXnav just seems to be advertising on it?
Old June 2nd 20, 11:30 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Yes, it does. Comes up when I power the unit on.
Old June 2nd 20, 11:32 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
I am picking up ADS-B traffic, with or without the transponder set to ON. My PowerFlarm has a mark on the top of the case that has ADS-B marked.
  #24
Old June 2nd 20, 11:33 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Thanks. I will try that next, in lieu of better advice.
Rob “4D”
  #25
Old June 3rd 20, 01:35 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Rob “4D”
https://flarm.com/support/tools-software/
Richard
www.craggyaero.com
  #26
Old June 25th 20, 01:26 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Booting it up with an empty USB stick worked! I then cleared the stick, again, and loaded one more time with the config file. All is well...
Thanks,
Rob
Flarm picking up my transponder Rob Cluxton[_2_] Soaring 31 May 7th 20 12:17 PM
PowerFlarm “Own Transponder Detection" Rate John Carlyle Soaring 18 July 21st 17 05:59 PM
PowerFLARM Transponder Alert Size John Carlyle Soaring 2 May 6th 13 04:33 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
OSH traffic picking up Jim Burns Piloting 16 July 22nd 06 08:48 PM
Copyright 2004-2025 AviationBanter.
