PowerFlarm still picking up Transponder
Old May 18th 20, 08:41 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Default PowerFlarm still picking up Transponder
After previous advice on here, I reconfigured my PowerFlarm via the .configtxt file. I am now seeing ADS-B traffic (definitely need to lower the altitude and distance parameters) but when I run my own transponder in ALT mode it’s still picking up traffic at 12 o’clock, .6 miles and around my altitude.
Anything else to recommend I try?
Rob
“4D”
Old May 18th 20, 09:01 PM posted to rec.aviation.soaring
Shot in the dark here, are you sure the code in your transponder matches what's in your Flarm config / which should be the one in the FAA database for your glider.
Old May 24th 20, 03:14 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
I’m sure the code/config file matches the Flarm ICAO code. Guess I have to try and find what the FAA has.
Old May 24th 20, 03:36 PM posted to rec.aviation.soaring
Dan Daly[_2_]
It would help if you post your flarmcfg.txt file here.
Old May 31st 20, 03:06 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Here it is:
# Cerated by LXNAV PowerFlarmConfig version 1.2.5
# This configuration file must be text only and reside in the top directory
# of the USB stick, SD card or FLARM Tool.
# This configuration file must be named FLARMCFG.TXT
# If you wish to change the settings, you can use PowerFlarmTool
# from: https://gliding.lxnav.com/lxdownloads/software/
# Basic Settings
$PFLAC,S,ID,AC2D0E
$PFLAC,S,NMEAOUT1,1
$PFLAC,S,NMEAOUT2,1
$PFLAC,S,ACFT,1
$PFLAC,S,CFLAGS,0
$PFLAC,S,PRIV,0
$PFLAC,S,NOTRACK,0
$PFLAC,S,THRE,1
# IGC Settings
$PFLAC,S,LOGINT,4
$PFLAC,S,PILOT,undefined
$PFLAC,S,COPIL,undefined
$PFLAC,S,COMPCLASS,undefined
$PFLAC,S,COMPID,undefined
$PFLAC,S,GLIDERID,undefined
$PFLAC,S,GLIDERTYPE,undefined
# Baud rate
$PFLAC,S,BAUD1,2
$PFLAC,S,BAUD2,2
# Range
$PFLAC,S,MODEC,1
$PFLAC,S,OWNMODEC,0
$PFLAC,S,XPDR,2
$PFLAC,S,MODESALT,0
$PFLAC,S,PCASRANGE,7408
$PFLAC,S,PCASVRANGE,610
$PFLAC,S,PCASPFLAU1,0
$PFLAC,S,PCASPFLAU2,0
$PFLAC,S,PCASBEEP,1
$PFLAC,S,PCASCALIBRATION,30
$PFLAC,S,ADSBRANGE,65535
$PFLAC,S,ADSBVRANGE,65535
$PFLAC,S,RANGE,2000
$PFLAC,S,VRANGE,500
# Device Settings
$PFLAC,S,AUDIOOUT,0
$PFLAC,S,AUDIOVOLUME,100
$PFLAC,S,BATTERYTYPE,0
$PFLAC,S,BRIGHTNESS,100
$PFLAC,S,VOL,3
Old May 31st 20, 03:44 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Here it is:
# Basic Settings
$PFLAC,S,ID,AC2D0E
$PFLAC,S,NMEAOUT1,1
$PFLAC,S,NMEAOUT2,1
$PFLAC,S,ACFT,1
$PFLAC,S,CFLAGS,0
$PFLAC,S,PRIV,0
$PFLAC,S,NOTRACK,0
$PFLAC,S,THRE,1
# IGC Settings
$PFLAC,S,LOGINT,4
# Baud rate
$PFLAC,S,BAUD1,2
$PFLAC,S,BAUD2,2
# Range
$PFLAC,S,MODEC,1
$PFLAC,S,OWNMODEC,0
$PFLAC,S,XPDR,2
$PFLAC,S,MODESALT,0
$PFLAC,S,PCASBEEP,1
$PFLAC,S,RANGE,2000
$PFLAC,S,VRANGE,500
# Device Settings
$PFLAC,S,AUDIOOUT,0
$PFLAC,S,VOL,3
Why are you using a LXNAV config file instead of a Powerflarm cfg tool.. They are not the same device, similar but not the same. the LXNAV is for config your PowerMouse, FlarmBat, FlarmMouse. It appears you are missing many config items. Let us start with a very important setting.
#PFLAC,S,DEF Sets Default
$PFLAC,S,DEF
Try turning off the PCAS $PFLAC,S,PCASRANGE,0 and see what happens.
Richard,
Old May 24th 20, 10:16 PM posted to rec.aviation.soaring
What brand of transponder are you using? Trig? If so, you’ll want to check what code is in the transponder. Not the 1202 VFR glider code, but your assigned aircraft code.
Go to the following link and start on page 29. Hold down the Fn button when you turn on your transponder and it will go into setup mode. Use the ENT button to move forward through the options. #2 should be the ICAO code and this should match what the FAA has assigned you and what is in your Flarm config file.
https://www.trig-avionics.com/librar...n%20Manual.pdf
Old May 24th 20, 10:38 PM posted to rec.aviation.soaring
George Haeh
If your transponder is Mode C, none of this will work.
1. The transponder, if Mode S, has to be configured to your ICAO code. Note that this is a specific process for your particular transponder that is set out in your transponder installation manual by the transponder manufacturer.
2. the PowerFLARM configuration file has to have the same ICAO code.
From Configuration tool:
" empty to use the device specific radio id..."
Old May 31st 20, 02:58 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
It’s a Garrecht VT-01
Old May 31st 20, 06:22 PM posted to rec.aviation.soaring
Just a side note, the VT-01 is not capable of supporting the necessary SIL level for use as ADSB-Out in the USA, at least. Where are you located?
Flarm picking up my transponder Rob Cluxton[_2_] Soaring 31 May 7th 20 12:17 PM
PowerFlarm “Own Transponder Detection" Rate John Carlyle Soaring 18 July 21st 17 05:59 PM
PowerFLARM Transponder Alert Size John Carlyle Soaring 2 May 6th 13 04:33 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
OSH traffic picking up Jim Burns Piloting 16 July 22nd 06 08:48 PM
