Halon Fire Extinguisher?
Old May 3rd 04, 03:21 AM
Roger Halstead
On Sun, 02 May 2004 16:01:47 GMT, "Jürgen Exner"
O. Sami Saydjari wrote:
I just got my first issue of "Light Plane Maintenance" magazine.
I am really enjoying it. In their free book "40 Top Maintenance Tips"
(p27), they say "get the Halon extinguisher while they are still
legal."
Halon has been banned years ago because it is one of the worst chemicals
wrt. destroying the ozone layer.
It was widely used in the 70s and possibly into the 80s, particularly
in computer rooms that might contain lots of personnel.
At several installations we had large process control computer rooms
That used Halon from large tanks located on a lower floor. It's been
a while but I'd guess these tanks might have been as large as 150
gallons. They were connected to the computer rooms through either a 3"
or 4" header pipe that had a number of outlets. These outlets did not
have fuseable links, or diffusers on them as with water. They were
wide open pipes and an extinguisher dump was something you did not
want to experience more than once.
Although these rooms were large, there weren't *that* large. They
were solid and tight, separated from the processes by a "blast wall".
I saw a 1 1/2 steel door that had been bent from an extinguisher dump.
The door was open about 1/3 of the way when the dump occurred. Had
the frame not been set in reinforced concrete it would have blown the
door in a spectacular fashion.
As I recall, there has been some issue that inhaling Halon can be
pretty bad for people's health.
There are several "gotchas" with Halon, but "in general you can inhale
Halon with no ill effects.
It is my understanding that it works differently than other
extinguishers by inhibiting the combustion process while still leaving
enough Oxygen in the air for survival.
Not really. Halon is non-toxic.
OTOH although Halon is non-toxic, at high temperatures it can generate
some very toxic gases. Really nasty stuff when it is broken down into
it's basic constituents.
Why is a Halon fire extinguisher a
great idea.
Because is it is non-toxic, very effective, non-corrosive, non-damaging,
doesn't leave a residue, and half a dozen other reasons.
To my way of thinking there are about the only safe thing to use in an
aircraft. Many have dry chemical extinguishers and using one of those
in a confined area is ... quite an experience. It'll leave a taste
in your mouth for quite a while, but you shouldn't suffer from acid
indigestion for a while be it a standard or Purple K (TM) charge.
Also, this might sound dumb, but don't C02 extringuisher work by
depriving fires of 0xygen?
Plus cooling the fire below the ingnition temperature.
It seems to me that in a small aircraft
cabin, one might also end up depriving the pilot and crew of oxygen as
well.
With the airflow through most small aircraft I'm not sure the CO2
extinguisher would be all that effective.
www.rogerhalstead.com
Only a concern for prolonged exposure.
Perhaps, one can survive long enough to put out the fire and
then open the air vents?!
Normal ventilation would probably even be enough.
jue
Old May 3rd 04, 03:19 PM
Jürgen Exner
G.R. Patterson III wrote:
chemicals wrt. destroying the ozone layer.
In the Americas, only the manufacture is banned. There's a small
industry recycling the stuff from old systems, and extinguishers are
still available and legal to own.
How come this doesn't surprise me?
From what I've read, possession is
banned in the EU.
AFAIK production and sales are illegal.
But you don't have to turn in your old extinguisher.
jue
Old May 3rd 04, 03:50 PM
Aaron Coolidge
Roger Halstead wrote:
snip
: With the airflow through most small aircraft I'm not sure the CO2
: extinguisher would be all that effective.
I was in the engine room of a cargo ship that had a CO2 extinguisher -
technically called a "smothering system" activate. Let's just say that
you *DO NOT* want to be anywhere near a CO2 system that's been activated.
As I recall, two men who couldn't get out were killed. The ship's engines
stopped within a minute due to lack of oxygen. I would *NEVER* shoot off
a CO2 extinguisher in any kind of confined space.
Aaron Coolidge
Old May 3rd 04, 04:03 PM
Don Tuite
On Mon, 03 May 2004 14:19:12 GMT, "Jürgen Exner"
So what's to become of your existing stocks?
No idea? How come this doesn't surprise me?
Don
Old May 4th 04, 10:27 PM
Roger Halstead
On Mon, 3 May 2004 14:50:56 +0000 (UTC), Aaron Coolidge
snip
I would think the cargo hold would be a lot tighter than the typical
small plane where the draft would blow out a match.
About the only one safe for a confined space is Halon. You'll choke
on a dry chemical. The stuff is terrible even in an office, let alone
an airplane.
I once was able to put my yearly training to use when we had a fire in
one of the construction trailers on site.
It was Winter and very cold. They had one of the old style Kerosene
stoves that were used in many homes. For safety it was set in a metal
pan about an inch to inch and a half deep. Thing was probably 4 feet
wide, two and a half across and maybe three feet tall. Of course it
was located way back at the end of the trailer which made good sense.
They had flooded it and when it started it got hot in a hurry, plus
there was a good half inch (or more) of kerosene in the pan. The
flames were boiling up and then following the ceiling about 20 feet to
the door where they were rolling out.
I had a 25# dry (Purple-K) extinguisher in each hand. I took a deep
breath and went in on my knees. (standing up would not have been
conducive to good health. It looked just like the training films with
the flames billowing across the ceiling the full length of the
trailer).
I don't remember how many extinguishers the construction crew had
used, but there were a bunch of them on the ground by the door. They
had been trying to put out the flames instead of the fire. It took
less than the one extinguisher to put out the fire, but that kerosene
was boiling hot and was filling the room with fumes... fast. As soon
as the flames were out, so was I. :-)) If that sucker relit it was
going to be noisy.
I was able to hold my breath long enough to go in, put out the fire,
and get out. With the heat and fumes, breathing in there would not
have been healthy. (It was Hot!)
You never, ever use CO2 in any confined space. That would be pressure
vessels, holes in the ground, and air tight rooms. They are fine in
the normal open office spaces.
CO2 does warn you though. It makes you feel like you need to breathe.
It is what keys, or triggers the breathing reflex, not the lack of
Oxygen. For instance with nitrogen in a confined space you have
absolutely no warning. You just go to sleep. Hence the requirement
for the complete harness and an outside safety man when entering
pressure vessels or holes in the ground.
We had a number of underground pumping stations. When I hired in,
we'd just go out, open the hatch, go in and check the instruments. By
the time I went back to college we couldn't even go in alone.
Complete harness and outside backup were minimum.
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Fire extinguisher question Kees Mies Owning 9 December 19th 03 10:12 PM
FA: halon fire ext system for homebuilts N329DF Home Built 0 August 16th 03 03:12 PM
FA: AIRCRAFT/RACE CAR HALON FIRE EXT SYSTEM N329DF Aviation Marketplace 0 August 16th 03 03:11 PM
hangar fire extinguisher [email protected] Owning 6 August 11th 03 01:01 AM
